Discuss
dryer wont start
 in
Dryer Repair
When I tried to start my dryer this morning it wouldn't start. when I pushed the start button and turned
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer wont start
  #1 (permalink)
Old 05-31-2009, 09:20 AM
Junior Member
buckeye55 is on a distinguished road
Default dryer wont start
Model Number: 87692800   Brand: Kenmore   Age: More than 10 years
When I tried to start my dryer this morning it wouldn't start. when I pushed the start button and turned the timer too the of position it would click like it was releasing. I took the switch out and checked it for continuity. When I pressed it, it showed it had continuity , but it does not stay engaged. Model# 11087692800
Ads By Google
Related Models
Magic Chef 8770RB Surface Unit - Ele
Magic Chef 8770RV Surface Unit - Ele
Whirlpool 8780000
Whirlpool 8780010
Jenn-Air 87848 Range - F/s Std Ddraft Ele
Jenn-Air 87849 Range - F/s Std Ddraft Ele
Jenn-Air 87849N
Jenn-Air 87849S
Whirlpool 8787000
Whirlpool 8787010
Whirlpool 8789000
Jenn-Air 87899 Misc / Accessory
Whirlpool 8790000
Whirlpool 8790010
Jenn-Air 87904 Ele Cartridge
Jenn-Air 87914 Misc / Accessory
Jenn-Air 87919 Misc / Accessory
Whirlpool 8794000
Niagra 8795-0 4000 WATT PORTABLE AC GENERATOR
Whirlpool 8797000
Whirlpool 8797010
Magic Chef 87LA-1 Surface Unit - Ele
Magic Chef 87LA-1G Surface Unit - Ele
Magic Chef 87LK-1 Surface Unit - Ele
Magic Chef 87LN-1 Surface Unit - Ele
Magic Chef 87LN-1G Surface Unit - Ele
Magic Chef 87LS-1 Surface Unit - Ele
Magic Chef 87LS-1G Surface Unit - Ele
Hoover 88
Amana 880.000 Range - S/c S/i Ddraft Gas
Amana 880.001 Range - S/c S/i Ddraft Gas
Amana 880.002 Mwave - Family Size (60 Hz)
Amana 880.003 Range - S/c S/i Ddraft Gas
Amana 880.004 Range - S/c S/i Ddraft Gas
Amana 880.110 Range - S/c S/i Ddraft Gas
Amana 880.120 Range - S/c S/i Ddraft Gas
Amana 880.130 Range - S/c S/i Ddraft Gas
Amana 880.130*1
Amana 880.130x1 Range - S/c S/i Ddraft Gas
Whirlpool 880652124P0 30" Electric Ceran Freestanding Range Standard Clean Oven
Whirlpool 8811W00
Whirlpool 8811^00
Whirlpool 8812W00
Whirlpool 8812^00
Whirlpool 8814W00
Whirlpool 8814^00
Whirlpool 8815W00
Whirlpool 8815^00
Jenn-Air 88168 Range - F/s Std Ddraft Ele
Jenn-Air 88169 Range - F/s Std Ddraft Ele
Whirlpool 8816W00
Whirlpool 8816^00
Jenn-Air 88170 Range - F/s Std Ddraft Ele
Whirlpool 8817W00
Whirlpool 8817W10
Whirlpool 8817^00
Jenn-Air 88186 Misc / Accessory
Whirlpool 8818W00
Whirlpool 8818^00
Whirlpool 8819W00
Whirlpool 8819^00
Whirlpool 8820W00
Whirlpool 8820^00
Whirlpool 8822W00
Whirlpool 8822^00
Jenn-Air 88353 Surface Unit - Ele
Jenn-Air 88353-8 Surface Unit - Ele
Jenn-Air 88368 Range - F/s Std Ddraft Ele
Jenn-Air 88369 Range - F/s Std Ddraft Ele
Jenn-Air 88370 Range - F/s Std Ddraft Ele
Jenn-Air 88371 Range - F/s Std Ddraft Ele
Jenn-Air 88372 Range - F/s Std Ddraft Ele
Jenn-Air 88889 Surface Unit - Ele
Jenn-Air 88890 Surface Unit - Ele
Jenn-Air 88891 Surface Unit - Ele
Magic Chef 88FK-1 Surface Unit - Ele
Magic Chef 88FK-2 Surface Unit - Ele
Magic Chef 88FK-6 Surface Unit - Ele
Magic Chef 88FN-1
Magic Chef 88FN-2 Surface Unit - Ele
Magic Chef 88FN-6 Surface Unit - Ele
Magic Chef 88LK-6 Surface Unit - Ele
Magic Chef 88LN-6 Surface Unit - Ele
Amana 890.000 Range - S/c S/i Ddraft Gas
Amana 890.001 Mwave - Family Size (60 Hz)
Amana 890.301 Mwave - Family Size (60 Hz)
Amana 890.302 Mwave - Family Size (60 Hz)
Amana 890.304 Mwave - Family Size (60 Hz)
Jenn-Air 89353 Surface Unit - Ele
Jenn-Air 89353-8 Surface Unit - Ele
Jenn-Air 89353-C Surface Unit - Ele
Amana 894.304 Mwave - Family Size (60 Hz)
Amana 894.307 Mwave - Family Size (60 Hz)
Amana 896.A Mwave - Family Size (60 Hz)
Amana 896.B Mwave - Family Size (60 Hz)
Whirlpool 8963L00
Whirlpool 8963L30
Jenn-Air 89889 Surface Unit - Ele
Jenn-Air 89889-C
Jenn-Air 89890 Surface Unit - Ele
Jenn-Air 89890-C Surface Unit - Ele
Jenn-Air 89891 Surface Unit - Ddraft Ele
Jenn-Air 89891-C
Magic Chef 89L-4 Surface Unit - Ele
Magic Chef 89L-6 Surface Unit - Ele
Whirlpool 8AC2504XS0
Whirlpool 8ACE07LD0
Whirlpool 8BLGR5636JQ0
Whirlpool 8BLGR5636JQ1 29"gas Dryer
Whirlpool 8CACM07DD0
Whirlpool 8CACM07DD1
Whirlpool 8CACM07ND0
Whirlpool 8CACM10DD1
Whirlpool 8ED0GTKXKQ00
Whirlpool 8ED0GTKXKQ01 Refrigerator
Whirlpool 8ED0GTKXKQ02 Refrigerator
Whirlpool 8ED0GTKXKT00
Whirlpool 8ED0GTKXKT01 Refrigerator
Whirlpool 8ED0GTKXKT02 Refrigerator
Whirlpool 8ED0WTKXKT00
  #2 (permalink)
Old 06-02-2009, 05:19 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Buckeye
Let's start by doing a few simple tests.
1. Use your meter to make certain you have 120 volts coming into the dryer.
2. Unplug the dryer, and tape the leads from the start switch together, then plug in the dryer. If it starts you have a bad start switch. Do not do this to operate the dryer, it is only for a test.
3. Do a continuity check on each of your thermostats and thermal fuse. If one is open, replace it.
4. Do a continuity test on your door switch. Check that you have continuity when the switch is engaged.
Let us know what you find out.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer wont start CHRIS KAKATES Dryer Repair 1 02-17-2010 04:13 PM
dryer wont start Merlin Dryer Repair 3 12-07-2009 05:41 PM
Gas dryer wont start nikita Dryer Repair 1 07-21-2009 11:09 AM
dryer wont start asguttx Dryer Repair 2 02-25-2009 04:21 AM
dryer wont start phyllis Dryer Repair 5 10-21-2008 02:24 PM
