HAYDEN1
#1 Posted : Saturday, May 30, 2009 9:27:26 AM(UTC)
HAYDEN1
Got From A Relative 2 Weeks Ago Had To Take Apart To Get Down Basement Steps Put Back Together And 2 Weeks Later Heater Element Burnt.could The Wires Be On Wrong?
#2 Posted : Sunday, May 31, 2009 4:47:39 AM(UTC)
Replacement parts for WHIRLPOOL KEYS750JQ0 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406699.pdf
Not quite sure what you mean!!
Has the heater element burnt out?
Please explain.
HAYDEN1
#3 Posted : Tuesday, June 2, 2009 7:07:55 AM(UTC)
HAYDEN1
Heater Element Burnt Out The Top Half Was Black
#4 Posted : Wednesday, June 3, 2009 12:37:00 AM(UTC)
I doubt the wires are wrong as it worked for 2 weeks.
HAYDEN1
#5 Posted : Thursday, June 4, 2009 4:38:44 AM(UTC)
HAYDEN1
When I Put It Back Together Could I Have Put The Wire On The Wrong Spot And Caused The Heater Element To Burn Out?
#6 Posted : Thursday, June 4, 2009 5:32:49 AM(UTC)
Depends how many wires you removed.
If you only removed the two wires going to the heater then no, as it makes no difference which connector the wires go to on the heater.
Note the the heater is rated for 240 volts which is the input voltage, there is really no way to hook it up where you would blow the heater.
Only install problem that might occur is if you somehow bent the heating element so that it touched the case (grounded element), this could burn out the element depending whereit was touching the case.
dryer won't heat up (Dryer Repair)
by dnell 8/26/2014 7:21:16 PM(UTC)
LG gas dryer won't heat up (Dryer Repair)
by Farmer85 10/2/2013 9:21:16 AM(UTC)
GE electric dryer won't heat up (Dryer Repair)
by jrogers 7/4/2013 11:55:26 AM(UTC)
by Teresay 6/11/2013 6:40:08 PM(UTC)
Dryer won't heat up (Dryer Repair)
by ford4wd08 6/11/2013 9:42:58 AM(UTC)
frigidaire dryer won't heat up (Dryer Repair)
by wilde1537 5/6/2013 10:27:04 AM(UTC)
Whirlpool Duet Gas Dryer Won't Heat Up (Dryer Repair)
by evanr99 2/1/2013 6:16:21 PM(UTC)
Maytag Electric Dryer won't heat up (Dryer Repair)
by rajpat25 7/7/2012 12:56:23 PM(UTC)
by d burns 5/17/2012 12:18:14 PM(UTC)
Bosch Dryer won't heat up (Dryer Repair)
by tericribb 3/18/2012 10:05:30 AM(UTC)
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up (Dryer Repair)
by NVChickey 2/25/2012 10:50:02 PM(UTC)
Dryer won't heat up to dry clothes (Dryer Repair)
by tdeai 7/21/2011 3:55:49 PM(UTC)
by krisr 2/8/2011 2:52:24 PM(UTC)
Heating Element on Roper Dryer won't heat up (Dryer Repair)
by c grass 11/23/2010 5:26:01 AM(UTC)
by WW47 7/29/2010 1:07:03 PM(UTC)
