Discuss
takes to long to dry
 in
Dryer Repair
how do I replace heating elements in a kenmore 80 series, heavy duty,king size dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » takes to long to dry
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-17-2007, 02:37 PM
jstyles jstyles is offline
Junior Member
jstyles is on a distinguished road
Default takes to long to dry
Model Number: 110.64892401   Brand: Kenmore   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-17-2007, 07:25 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
if there is heat at start ,i would check the venting at back of dryer to out side. could be blocked or kinked.turn dryer on ,go outside ,check for good air flow, if little flow or none then venting is problem. you can remove venting at back of dryer +test drying a load to see if dryer is fine +venting is problem
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer takes to long to dry Julito Dryer Repair 1 12-05-2007 12:10 PM
Dryer Takes way to long to dry confused Dryer Repair 4 08-12-2007 08:38 PM
Takes too long to dry:Duet Scottpiggs Dryer Repair 4 08-10-2007 12:49 PM
oven takes long time to cook Wmurky Oven Repair (including Ranges and Cooktops) 2 07-29-2007 12:01 PM
Dryer Takes Very Long to Dry Clothes jdavis Dryer Repair 2 07-25-2007 04:00 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
