I have a Kenmore elite gas dryer model # 11092822101 that won't heat. I've removed and tested the thermal fuse, and the high temp thermost with a continuity tester and the both worked. I tested my gas valve coils, since that was the next item listed in the tech sheet, and both of them were high and outside of the spec range. I replaced both of them and still no flame! What should I do next? The tech sheet says replace the machines controls.
