Hi, My Maytag dryer timer does not advance. It simply does not shut off except manually. I have replaced the timer twice. The serial # is 23469798EA. I have purchased Part # AP4042973 which did not work and also Part #AP4042974 which also did not work. The dryer works fine. What else could it be? Replacing the timer only involves pluging in the bus cable. Where else could the problem lie? Many thanks.
