Discuss
Dryer overheated - belt issue? How to replace?
 in
Dryer Repair
I have a Whirlpool dryer, model LE4905XMW1, and yesterday it overheated. I had accidentally not seated the kidney-shaped lint screen
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer overheated - belt issue? How to replace?
  #1 (permalink)
Old 05-28-2009, 10:58 AM
Junior Member
crussell01 is on a distinguished road
Question Dryer overheated - belt issue? How to replace?
Model Number: LE4905XMW1   Brand: Whirlpool   Age: More than 10 years
I have a Whirlpool dryer, model LE4905XMW1, and yesterday it overheated. I had accidentally not seated the kidney-shaped lint screen / trap into the back of the unit properly and while the dryer was running it fell out, causing some clothing to become stuck in the lint passage. The dryer stopped spinning and I could smell a burnt rubber smell. I removed all clothing from the lint passage and replaced the lint screen, and after the unit cooled off for a couple hours it would start spinning again BUT, I still smell that burnt smell while it's running (though not as strongly as before) so I'm unable to use it. It smells very much like the belt was burnt a bit. Would you agree that this is a logical conclustion, and that it's not a problem within the motor itself?
I plan to order the replacement belt however the instruction manual for this unit is no longer available, according to the nice gentleman whom I called there at ApplicanePartsPros.com. He suggested that I submit my questions here. What I would like to ask is: how does one replace the belt on this older model of Whirlpool portable dryer? I've already installed a replacement pwoer cord for this unit and that was very easy, so I'm hoping that replacing the belt is also easy. And my other question is: does this sound like it's a belt issue and not something more serious affecting the actual motor or another part? Thanks very much for your help.
Ads By Google
Related Models
Whirlpool LE4905XMW1
Amana LE4907L Dryer - Ele
Amana LE4907W Dryer - Ele
Whirlpool LE4930XKW0
Whirlpool LE4930XMW0
Whirlpool LE4930XMW1
Whirlpool LE4930XSW0
Whirlpool LE4930XTF0
Whirlpool LE4930XTG0
Whirlpool LE4930XTM0
Whirlpool LE4930XTN0
Whirlpool LE4930XTN1
Whirlpool LE4930XTN2
Whirlpool LE4930XTW0
Whirlpool LE4930XTW1
Whirlpool LE4930XTW2
Whirlpool LE4935XMW0
Whirlpool LE4935XMW1
Whirlpool LE5200XTF0
Whirlpool LE5200XTG0
Whirlpool LE5200XTM0
Whirlpool LE5200XTN0
Whirlpool LE5200XTN1
Whirlpool LE5200XTW0
Whirlpool LE5200XTW1
Whirlpool LE5320XTF0
Whirlpool LE5320XTG0
Whirlpool LE5320XTM0
Whirlpool LE5320XTN0
Whirlpool LE5320XTW0
Whirlpool LE5530XKW0
Whirlpool LE5530XKW1
Whirlpool LE5530XKW2
Whirlpool LE5530XMW0
Whirlpool LE5530XMW1
Whirlpool LE5530XMW2
Whirlpool LE5530XPW0
Whirlpool LE5530XSW0
Whirlpool LE5530XSW1
Whirlpool LE5535XPW0
Whirlpool LE5550XTG0
Whirlpool LE5550XTN0
Whirlpool LE5550XTW0
Whirlpool LE5600XKW0
Whirlpool LE5600XMW0
Whirlpool LE5600XPW0
Whirlpool LE5600XSW0
Whirlpool LE5600XSW1
Whirlpool LE5605XPW0
Whirlpool LE5650XKW0
Whirlpool LE5650XKW1
Whirlpool LE5650XMW0
Whirlpool LE5650XMW1
Whirlpool LE5650XMW2
Whirlpool LE5700XKW0
Whirlpool LE5700XKW1
Whirlpool LE5700XMW0
Whirlpool LE5700XMW1
Whirlpool LE5700XMW2
Whirlpool LE5700XPW0
Whirlpool LE5700XSW0
Whirlpool LE5705XPW0
Whirlpool LE5705XPW1
Whirlpool LE5720XPW0
Whirlpool LE5720XSG1
Whirlpool LE5720XSW0
Whirlpool LE5720XSW1
Whirlpool LE5725XPW0
Whirlpool LE5750XFW0
Whirlpool LE5750XKW0
Whirlpool LE5750XKW1
Whirlpool LE5750XKW2
Whirlpool LE5750XMW0
Whirlpool LE5750XMW1
Whirlpool LE5760XSN1
Whirlpool LE5760XSW0
Whirlpool LE5760XSW1
Whirlpool LE5770XWN0
Whirlpool LE5770XWW0
Whirlpool LE5780XKW0
Whirlpool LE5780XKW1
Whirlpool LE5780XMW0
Whirlpool LE5780XMW1
Whirlpool LE5780XMW2
Whirlpool LE5790XMW0
Whirlpool LE5790XMW1
Whirlpool LE5790XPW0
Whirlpool LE5790XSW0
Whirlpool LE5790XSW1
Whirlpool LE5795XMW0
Whirlpool LE5795XPW0
Whirlpool LE5795XPW1
Whirlpool LE5800XKW0
Whirlpool LE5800XKW1
Whirlpool LE5800XMW0
Whirlpool LE5800XMW1
Whirlpool LE5800XMW2
Whirlpool LE5800XPW0
Whirlpool LE5800XPW1
Whirlpool LE5800XSW0
Whirlpool LE5800XSW1
Whirlpool LE5800XSW2
Whirlpool LE5800XSW3
Whirlpool LE5805XPW0
Whirlpool LE5810XPW0
Whirlpool LE5900XSW0
Whirlpool LE5920XKW0
Whirlpool LE5920XKW1
Whirlpool LE5920XMW0
Whirlpool LE5920XMW1
Whirlpool LE5920XMW2
Whirlpool LE5950XSW0
Frigidaire LE600AXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600AXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD3 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXW1 Wwh(v1) / 27 " Laundry Center
  #2 (permalink)
Old 05-29-2009, 08:17 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I am not familiar with that model, but I think if I were my advice would still be the same.
Unfortunately, odor issues are very difficult to diagnose from afar because, well, we cannot smell what you are smelling. It is not likely that your belt is the problem, it either pretty much works or it does not work and if it were slipping and making the odor for that reason you drum would not turn or turn very fast. I don't think the belt could have become burnt and cause your smell.
Given that the dryer came to a halt the most likely culprit is your motor. Given the age of your machine I would think it is time for a replacement. Also, you do not want the potential safety problems with a motor that is on its way out. Rather than put money into this machine, with a little more you can get a nice, recent, used machine or a new, basic dryer, which is all most people need is not expensive.
Sorry I could not be more positive, but good luck and let us know what you decide.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
need to replace dryer belt Barbara Krul Dryer Repair 3 09-16-2009 10:22 AM
Whirlpool dryer will not tumble. Belt issue? marc127 Dryer Repair 3 08-31-2009 03:18 PM
Replace belt issue thammond Washer Repair 4 06-10-2009 08:15 AM
replace dryer belt Jack Hunsicker Dryer Repair 4 03-11-2009 04:29 PM
Replace Dryer Belt sls Dryer Repair 1 05-05-2008 06:05 PM
