Discuss
maytag Electric dryer
 in
Dryer Repair
Dry runs but does not heat. No obstruction. Had broken wire from one of the heating coil. Repaired, still no
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » maytag Electric dryer
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-05-2007, 05:04 PM
gws001 gws001 is offline
Junior Member
gws001 is on a distinguished road
Default maytag Electric dryer
Model Number: lde512   Brand: Maytag   Age: More than 10 years
Dry runs but does not heat. No obstruction. Had broken wire from one of the heating coil. Repaired, still no heat.
Presume that a fuse is blown but find none.
Gerry
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-06-2007, 05:34 AM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Check to make sure you have 240 volts to the dryer.
Video: How to check voltage at cord on a Maytag electric dryer.
  #3 (permalink)
Old 08-06-2007, 07:21 AM
Junior Member
Default
Thank you. We have been having some problems with brown outs recently. The circuit breaker is not tripped. However, I will check the voltage this afternoon and get back to you.
Gerry
  #4 (permalink)
Old 08-06-2007, 10:23 AM
Junior Member
Default
Voltage tests at 120 on each side of the terminal on back of the unit. Using the common in the middle, I tested each side and got the same reading on each.
Thank You
Gerry
  #5 (permalink)
Old 08-06-2007, 10:40 AM
Senior Expert
APP Volunteer
Default
There is a thermo fuse on the heating element and the blower housing.
You can check them with a ohm meter. They should be closed (shorted) if the are ok.
If one is open (like a bad fuse) then replace it.
If you find a bad one you can jump the two wires out just for testing to see if it heats.
  #6 (permalink)
Old 08-06-2007, 11:47 AM
Junior Member
Default
There are three thermal fuses on the unit. Two on the blower cover and one on the heating unit.The two on the blower housing have three tabs. The 2 outside tabs show continuity on each. No continuity on the third tab. It seems to connect the two fuses.
The Thermal fuse on the heating unit has two tabs and it shows continuity.
Each shows continuit to the one on the heating uint and the upper connection to the heating element. Testing the heating element shows continuity between both terminals.
Still no heat.
Thank you
Gerry
  #7 (permalink)
Old 08-06-2007, 03:28 PM
Senior Expert
APP Volunteer
Default
Then you need to check for 240 volts at the heater when it is running.
If you have voltage there, then something is not yet right with the heating element.
If you do not have voltage you will have to trace it back to were you do.
  #8 (permalink)
Old 08-07-2007, 12:34 PM
Junior Member
Default
Thank you
Can I test this by checking voltage across both ends of the heater element while the unit is running? I suspect the main black wire attached to one of the heater coil posts. It comes from behind the drum. It may have pulled out. on the far end. Does it come from the timer switch in the header panel? Initially this wire was broke and I repaired it. I may have pulled it too hard for access for the repair.
  #9 (permalink)
Old 08-07-2007, 12:41 PM
Junior Member
Default
I tested across the heater coil posts with the unit running and found that I had no voltage at the coil. I will trace the main wire back to see where it is failing.
Gerry
  #10 (permalink)
Old 08-07-2007, 01:32 PM
Junior Member
Default
I have continuity from the timer switch to the heater coil tracing the black wire. I also have continuity from the black wire on the power block to the heater panel.
Could it be the timer?
Thank you
Gerry
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag electric over way too cold! tigerpilot Oven Repair (including Ranges and Cooktops) 2 07-30-2007 05:53 PM
Maytag Dryer: Drum Not Turning miatahowie Dryer Repair 2 07-26-2007 07:18 AM
Electric Dryer too hot jim k Dryer Repair 3 07-25-2007 04:43 PM
whirlpool electric coil cooktop jaffej Oven Repair (including Ranges and Cooktops) 0 07-25-2007 09:06 AM
electric range/oven clock not working 50fbn Oven Repair (including Ranges and Cooktops) 1 07-20-2007 11:47 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
