| » maytag Electric dryer |
gws001
You said there is no 240V to the heater. I would recommend to check the power separate between each wire (wires should be disconnected from the heater) and the ground. Probably you'll find a 120V on the one wire and nothing on the another. Trace the wire with no power and see were it's going. The problem is some were there and it could be the timer too but I do not want you to waist money. Let me know your findings. Be very careful working under the power! Good luck. Gene. |
Thank You
I tried a different timer out of a working unit and still have no heat. I am not sure about checking power separate between each wire. I have a black wire at the heater on one side and the other side comes from the temperature control sensors on the blower and the heating element. With all wires cisconnected on the heating element, I still get continuity through the heating coil. I get separate continuity through eaxh of the temperature controls with the wires disconnected. I also get continuity through them through the heating coil. |
Again Thank YOU
I solved the problem. I checked the wiring diagram and found that the wire that I had mended came off from the motor to the Heating coil, probably while I was working on it. I had to take out the drum to find that it had disconnected at the motor. I reattached it and found heat. However I now need to put it back together. Wish me luck. |
| Display Modes | |
| Maytag electric over way too cold! | tigerpilot | Oven Repair (including Ranges and Cooktops) | 2 | 07-30-2007 06:53 PM |
| Maytag Dryer: Drum Not Turning | miatahowie | Dryer Repair | 2 | 07-26-2007 08:18 AM |
| Electric Dryer too hot | jim k | Dryer Repair | 3 | 07-25-2007 05:43 PM |
| whirlpool electric coil cooktop | jaffej | Oven Repair (including Ranges and Cooktops) | 0 | 07-25-2007 10:06 AM |
| electric range/oven clock not working | 50fbn | Oven Repair (including Ranges and Cooktops) | 1 | 07-21-2007 12:47 AM |
