Discuss
Dryer has no heat but runs
 in
Dryer Repair
dryer spins but no heat, recently moved the dryer to a different location and bumped it a bit. It is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer has no heat but runs
  #1 (permalink)
Old 07-19-2007, 03:29 PM
Ron L. Ron L. is offline
Junior Member
Ron L. is on a distinguished road
Talking Dryer has no heat but runs
Model Number: LE6810XSWO   Brand: Whirlpool   Age: More than 10 years
dryer spins but no heat, recently moved the dryer to a different location and bumped it a bit. It is at least 18 years old and would like to keep it running a few more years: what parts are the most likely to need replacement?
Related Models
Whirlpool LE6880XSW0
Whirlpool LE6880XSW1
Whirlpool LE6880XTF0
Whirlpool LE6880XTG0
Whirlpool LE6880XTG1
Whirlpool LE6880XTM0
Whirlpool LE6880XTN0
Whirlpool LE6880XTN1
Whirlpool LE6880XTW0
Whirlpool LE6880XTW1
Whirlpool LE6900XKW0
Whirlpool LE7000XKW0
Whirlpool LE7000XMW0
Whirlpool LE7000XMW1
Whirlpool LE7000XMW2
Whirlpool LE7000XPW0
Whirlpool LE7000XSW0
Whirlpool LE7000XTG0
Whirlpool LE7000XTN0
Whirlpool LE7000XTW0
Whirlpool LE7005XPW0
Whirlpool LE7010XPW0
Whirlpool LE7010XSW0
Whirlpool LE7080XSW0
Whirlpool LE7080XSW1
Whirlpool LE7080XTF0
Whirlpool LE7080XTG0
Whirlpool LE7080XTG1
Whirlpool LE7080XTM0
Whirlpool LE7080XTN0
Whirlpool LE7080XTN1
Whirlpool LE7080XTW0
Whirlpool LE7080XTW1
Amana LE7101LB Dryer - Ele
Amana LE7101WB Dryer - Ele
Amana LE7111LB Dryer - Ele
Amana LE7111LM Dryer - Ele
Amana LE7111WB Dryer - Ele
Amana LE7111WM Dryer - Ele
Amana LE7121LM Dryer - Ele
Amana LE7121WM Dryer - Ele
Amana LE7153LB Dryer - Ele
Amana LE7153LM Dryer - Ele
Amana LE7153WB Dryer - Ele
Amana LE7153WM Dryer - Ele
Amana LE7163LM Dryer - Ele
Amana LE7163WM Dryer - Ele
Whirlpool LE7680XMW0
Whirlpool LE7680XPW0
Whirlpool LE7680XSW0
Whirlpool LE7680XSW1
Whirlpool LE7685XPW0
Whirlpool LE7685XPW1
Whirlpool LE7700XWN0
Whirlpool LE7700XWW0
Whirlpool LE7760XWN0
Whirlpool LE7760XWW0
Whirlpool LE7800XKW0
Whirlpool LE7800XKW1
Whirlpool LE7800XMW0
Whirlpool LE7800XMW1
Whirlpool LE7800XMW2
Whirlpool LE7800XMW3
Whirlpool LE7800XPW0
Whirlpool LE7800XSW0
Whirlpool LE7800XSW1
Whirlpool LE7800XSW2
Whirlpool LE7800XSW3
Whirlpool LE7805XPW0
Whirlpool LE7810XPW0
Amana LE8107L2 Washer - Top Loading
Amana LE8107W2 Dryer - Ele
Amana LE8207L2 Washer - Top Loading
Amana LE8207L3 Washer - Top Loading
Amana LE8207W2 Dryer - Ele
Amana LE8207W2B Dryer - Ele
Amana LE8207W3 Dryer - Ele
Amana LE8217L2 Dryer - Ele
Amana LE8217W2 Dryer - Ele
Amana LE8267L2 Washer - Top Loading
Amana LE8267W2 Dryer - Ele
Amana LE8317L2 Dryer - Ele
Amana LE8317W2 Dryer - Ele
Amana LE8317W2B Dryer - Ele
Amana LE8327W Dryer - Ele
Amana LE8367L2 Washer - Top Loading
Amana LE8367W2 Dryer - Ele
Amana LE8407L2 Dryer - Ele
Amana LE8407W Dryer - Ele
Amana LE8407W2 Dryer - Ele
Amana LE8457L2 Dryer - Ele
Amana LE8457W Dryer - Ele
Amana LE8457W2 Dryer - Ele
Amana LE8467L2 Dryer - Ele
Amana LE8467W2 Dryer - Ele
Amana LE8507W Dryer - Ele
Amana LE8517L2 Dryer - Ele
Amana LE8517W2 Dryer - Ele
Amana LE8517W2B Dryer - Ele
Amana LE8567L2 Dryer - Ele
Amana LE8567W2 Dryer - Ele
Whirlpool LE8600XWN0
Whirlpool LE8600XWW0
Amana LE8607L2 Dryer - Ele
Amana LE8607W Dryer - Ele
Amana LE8607W2 Dryer - Ele
Whirlpool LE8650XWN0
Whirlpool LE8650XWW0
Whirlpool LE8860XWQ0
Amana LE9002 Dryer - Ele
Amana LE9012 Washer - Top Loading
Whirlpool LE9100XTN0
Whirlpool LE9100XTN1
Whirlpool LE9100XTW0
Whirlpool LE9100XTW1
Amana LE9107W Dryer - Ele
Whirlpool LE9200XWN0
Whirlpool LE9200XWN1
Whirlpool LE9200XWW0
Last edited by Ron L. : 07-19-2007 at 03:49 PM. Reason: make question more specific
  #2 (permalink)
Old 07-19-2007, 04:50 PM
Admin / APP Team's Avatar
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Hi Ron,
I can't tell you exactly what the problem is, but I can give you a few pointers. Make sure to unplug the dryer first.
Breakdown diagrams for model LE6810XSW0 for reference.
Starting from the beginning:
1. Check the circuit breakers (both of them). Electric dryers run on two 110 volt breakers. It is possible that one of the breakers is tripped even with the dryer motor still working.
2. Remove the rear panel of the dryer.
Check the main terminal block (make sure all 3 wires are securely attached). Take a look at various components and see if you can spot a loose wire. Then check the thermal fuse with a voltmeter for continuity - open=bad, closed=good. Do the same test with the heating element (use the diagram link above for part locations). And check the thermal cutoff for continuity as well (the thermal cutoff is located on the heating element housing).
Run these tests and let us know what you find.
Also, while you have the back off, use a vacuum cleaner to get rid of as much lint as possible (don't forget to clean the lint chute).
Post back...
  #3 (permalink)
Old 07-23-2007, 08:48 AM
vincent key vincent key is offline
Junior Member
vincent key is on a distinguished road
Default Dryer has no heat but runs
I have a Frigdaire dryer model# FDE336RES2 thgat runs but has no heat trying to find out what might be the likely problem.
Thanks,
Vincent
  #4 (permalink)
Old 11-02-2007, 02:43 PM
mvetri mvetri is offline
Junior Member
mvetri is on a distinguished road
Default
Vincent, I have a Frigidaire model FDG336NBS1 witht he same problem. Have you found why you get no heat? My dryer works fine but no heat.
  #5 (permalink)
Old 11-02-2007, 09:53 PM
Junior Member
Default dryer works, but no heat
Yes I finally figured out the problem. I had a split breaker and was only getting a 120 volts instead of 240 volts. I hope this helps you out.
Thanks,
Vincent
  #6 (permalink)
Old 11-19-2007, 03:04 AM
Administrator
APP Team
Default
That's good to hear, Vincent. Always start with the basics (see my post at the beginning of this thread).
Mvetri -- If your dryer igniter glows but gas valve won't open, the likely cause is bad valve coils. If igniter does not glow, could be due to a bad flame sensor or igniter itself.
coils:
sensor
igniter
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #7 (permalink)
Old 07-17-2008, 08:09 PM
cdkbride cdkbride is offline
Junior Member
cdkbride is on a distinguished road
Default
I have a Maytag dryer that the igniter comes on,glows and the gas will not light.If the unit is shut off for about 10 min. or so the burner will ignight but will only stay on 2 min. and then will go out.I was wondering if the coil kit needs to be replaced and what is involed with that.It appears that they are plug in electric parts?Where are they located?(by burner?)
  #8 (permalink)
Old 06-15-2009, 11:12 AM
TomGJohnson TomGJohnson is offline
Junior Member
TomGJohnson is on a distinguished road
Default
I have the same problem...heats up once but next time the ignitor glows there is no gas. Is that the coil or a sensor?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer runs, but no heat bluky Dryer Repair 1 12-21-2009 02:36 AM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
dryer runs no heat Jim Bags Dryer Repair 1 09-01-2009 05:23 AM
Gas dryer runs but won't heat sblack Dryer Repair 1 10-07-2008 02:41 AM
Dryer runs no heat glennb Dryer Repair 1 08-10-2007 10:24 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
