| » Whirlpool Duet Electric Dryer |
Model Number: GEW 9200 LW1 Brand: Whirlpool Age: 5 - 10 years
The electric dryer does not seem to heat up. It seems to operate okay otherwise
Sandie R
Please start your own thread using "Post New Topic" unless the model and the problem are the same. Sandi Van Camp Here are your parts Replacement parts for WHIRLPOOL GEW9200LW1 Electric Dryer | AppliancePartsPros.com See the attachment for the tech sheet. First check the power to the unit. The heating coils require the full 240 volts but the motor and control board only require half the line (120volts) Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Be careful as 240 volts is lethal !!! Next would be the heating coil itself, should be 8 to 12 ohms. Then the thermal cut-off and high limit thermostat, both should be 0 ohms. Then the thermistor, about 10,000 ohms at room temperature. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. 4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset. There is a good STICKY at the start of this forum about it's use.
__________________
| Display Modes | |
| Whirlpool Duet Electric Dryer does not turn on | vong | Dryer Repair | 3 | 11-04-2011 04:48 AM |
| Whirlpool Duet electric dryer wont start | miketieman | Dryer Repair | 1 | 06-21-2011 06:05 AM |
| whirlpool duet electric dryer works but no heat | sbfire370 | Dryer Repair | 2 | 04-13-2011 11:59 AM |
| Whirlpool Duet Electric Dryer | Corey Pantuso | Dryer Repair | 0 | 12-16-2010 08:40 AM |
| Electric whirlpool duet dryer won't heat | LEhart | Dryer Repair | 1 | 11-18-2008 07:45 AM |
