Discuss
Amana dryer gas
 in
Dryer Repair
Trying To Replace The Roller Drum. The Only Way To Remove Is By Removing The Set Screw In The Center.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana dryer gas
  #1 (permalink)
Old 12-16-2007, 03:57 PM
augie0629 augie0629 is offline
Junior Member
augie0629 is on a distinguished road
Default Amana dryer gas
Model Number: LG4309W   Brand: Amana   Age: More than 10 years
Trying To Replace The Roller Drum. The Only Way To Remove Is By Removing The Set Screw In The Center. How Do You Remove The Screw? And Is There Any Way Of Doing This With Some Room From The Front? Thanks Paul
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-16-2007, 07:55 PM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
are you sure that there are not clips in front of the drum roller that can be removed ( using a specific tool for that clip ) by opening the clip up slightly and removing it then just sliding roller right off ( need to make sure belt is removed from tension pulley and motor..
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana dryer top removal gremlin Dryer Repair 2 08-05-2008 06:47 PM
Amana ref. problems wayfran1 Refrigerator & Freezer Repair 1 06-18-2008 02:02 PM
Amana Agitater Pop Washer Repair 1 12-06-2007 03:16 PM
High Pitched squeak in Dryer - AMANA Tmcjury Dryer Repair 0 11-06-2007 12:23 PM
Amana Electric Dryer- No Heat didier Dryer Repair 1 10-26-2007 08:25 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
