Discuss
Automatic shutdown
 in
Dryer Repair
I have a kitchen Aide dryer that is about 10 years old that doesn't shut down when the clothes
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Automatic shutdown
  #1 (permalink)
Old 05-25-2009, 10:10 AM
daverino daverino is offline
Junior Member
daverino is on a distinguished road
Default Automatic shutdown
Brand: Kitchen Aid   Age: More than 10 years
I have a kitchen Aide dryer that is about 10 years old that doesn't shut down when the clothes are dry in the automatic mode. It drys ok in the timed mode. What could the problem be?
  #2 (permalink)
Old 05-25-2009, 03:30 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Difficult to be real definitive without a model number, but in general what happens in automatic mode is the moisture sensor tells the timer not to advance until the clothes are nearly dry, and then the timer starts and finishes the cycle.
I imagine your moisture sensor system is not working properly, and is never telling the timer that the clothes are almost dry and to start moving towards shutoff.
You can try to fix it, and if you want some help post the model number, but my advice in a machine this old is just to use the timed dry. With a little experience you will find you can set it just about right, in fact it may be more efficient this way and save on some energy bills because in my experience folks set the automatic in such a way as to overdry the clothes.
__________________
  #3 (permalink)
Old 05-25-2009, 06:51 PM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Need a Model Number
On many old units the timer only advances in Auto modes when the heating element turns off.
Could be a resistor which drops the 240 volts to 120 volts for the timer motor.
Could be a grounded element.
Also a couple other things but need a wiring diagram.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven shutdown thermal fuse tony3333 Oven Repair (including Ranges and Cooktops) 1 05-12-2009 08:38 AM
whirlpool automatic dry doesn't dry pico111 Dryer Repair 2 08-06-2008 07:15 PM
GE Automatic Icemaker wfree Refrigerator & Freezer Repair 1 07-16-2008 12:00 PM
Automatic ON tdaughton Oven Repair (including Ranges and Cooktops) 1 03-18-2008 05:16 PM
Ignitors Won't Shutdown rlawrence Dishwasher Repair 6 01-25-2008 04:29 PM
