This old gas dryer has a burner valve type 689792. The replacement coil kit is 279137 When I remove one of the old coils, gas escapes around the vale stem. There is an "O-ring" around the stem. Is this the seal for the gas? Should gas be able to escape at this point? Is the valve internally damaged? I would have thought the stem would be isolated from contact with gas. Does anyone have a drawing showing the valve's construction?
