Discuss
Whirlpool gas dryer
 in
Dryer Repair
Dryer heats up for a few minutes and then starts to cool down. Will not heat up after that. I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool gas dryer
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-16-2007, 10:24 AM
Paul Solarz Paul Solarz is offline
Junior Member
Paul Solarz is on a distinguished road
Default Whirlpool gas dryer
Model Number: LG6151XSW1   Brand: Whirlpool   Age: More than 10 years
Dryer heats up for a few minutes and then starts to cool down. Will not heat up after that. I have cleaned the duct work and internal parts. I am guessing the thermostat is bad, but notice there are two on the parts list for Whirlpool. Do I replace both ? Also, on the site the part does not look the same as it does on my dryer....
Any help would be great. I'm sure I can change these myself.
Paul
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-16-2007, 10:30 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
if the hot surface ignitor still continues to try to ignite the gas, and the gas never comes ( which never comes out ) then, more than likely your problem is with the coils on your gas valve in the dryer ...
__________________
regards
jim
  #3 (permalink)
Old 12-16-2007, 11:21 AM
Junior Member
Default
Thanks Jim, so what do you think, call a repair tech ?
  #4 (permalink)
Old 12-16-2007, 02:25 PM
Senior Expert
APP Volunteer
Default
well it depends on how handy you are ? if you see the glow of the ignitor and the gas never comes on , replacing the coils on top of the gas valve is really pretty easy... if you are electrically oriented then diagnosing a thermal cut out / thermostat problem is not that bad either .. set the dryer for low temp for 60 minutes and after 20 minutes pull the toe kick / kick plate off and see if you see the ignitor ( glo-bar ) cycle on / off ?
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Gas Dryer Mike B. Dryer Repair 0 12-09-2007 08:59 AM
Whirlpool Dryer IrmaE Dryer Repair 3 11-17-2007 11:05 PM
Whirlpool Dryer babe milam Dryer Repair 1 11-14-2007 12:52 PM
Whirlpool Dryer babe milam Dryer Repair 1 11-14-2007 11:46 AM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
