Discuss
Dryer wont come on
 in
Dryer Repair
On the roor switch it clicks does that mean that the door switch is good? it not how do i
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer wont come on
  #1 (permalink)
Old 12-16-2007, 10:44 AM
sagen sagen is offline
Junior Member
sagen is on a distinguished road
Thumbs down Dryer wont come on
Model Number: LER7646EZ1   Brand: Whirlpool   Age: More than 10 years
On the roor switch it clicks does that mean that the door switch is good? it not how do i check the switch? i have a green, a red and a white wire .
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-16-2007, 10:51 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
easy way to check door switch ( with POWER OFF ) is to put the two wires together or "jump" switch (bypass) .. if the dryer works, the door switch was your problem... with an ohm meter put your leads on the terminals of the door switch ( hopefully with aligator clips ) and with a digital ohm meter as the switch closes, the value of the meter should come close to 1 or beep.. if it doesnt change, the switch is NG..
__________________
regards
jim
  #3 (permalink)
Old 12-16-2007, 08:34 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
also check thermal fuse at back .white plastic with 2 connectors
  #4 (permalink)
Old 12-17-2007, 09:18 AM
Junior Member
Default Dryer will not start
I fount the problem the Thermal Fuse is out. I un pluged the wires put a jumper and press start dryer came on. Now i have to order that fuse.
Thanks Edell
  #5 (permalink)
Old 12-17-2007, 09:47 AM
Senior Expert
APP Volunteer
Default
when you get the new thermal fuse,it will say to check cycling t-stat and venting .. either or could cause the new one to fail again...
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer wont come on sagen Dryer Repair 1 12-16-2007 09:01 AM
dryer wont start debbie Dryer Repair 3 10-14-2007 04:40 AM
Dryer wont heat mike54487 Dryer Repair 1 10-09-2007 03:40 AM
dryer wont heat tom46151 Dryer Repair 1 09-10-2007 06:56 AM
Dryer wont turn on angierg Dryer Repair 0 09-04-2007 04:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
