Discuss
Frigidaire Electric Dryer
 in
Dryer Repair
We just replaced the rear drum bearing - no problems - I believe we have messed up the door switch.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire Electric Dryer
  #1 (permalink)
Old 05-24-2009, 05:00 PM
Junior Member
cafero99 is on a distinguished road
Default Frigidaire Electric Dryer
Model Number: FDE336RES1   Brand: Frigidaire   Age: 5 - 10 years
We just replaced the rear drum bearing - no problems - I believe we have messed up the door switch. I need to know if the switch was put back together correctly - thanks!!!!!
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 05-25-2009, 03:08 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is a parts breakdown
Replacement parts for FRIGIDAIRE FDE336RES1 | AppliancePartsPros.com
Here is a wiring diagram for a S2 unit, could not find a S1 diagram
http://manuals.frigidaire.com/prodin.../131850300.pdf
Cannot say from here if you installed it wrong.
First I would open the door, hold the switch closed and give it a try.
Could be the door is not holding the switch closed properly.
If OK
Check that the unit is getting the correct power 120 volts L1 to Neutral and L2 to Neutral also 240 volts L1 to L2. Sometimes you can loose half the line without actually tripping the breaker. Perhaps try turning the breaker off/on slowly a couple times. Best to check it with a meter.
If OK
You will have to open the unit up again and check that both wires are attached.
If OK
Then it would be easiest to get a meter so you can check the various parts in the start circuit.
__________________
  #3 (permalink)
Old 08-20-2009, 07:06 PM
Junior Member
hey,ck is on a distinguished road
Default
AGHHH!!! this has just happened to me too! i replaced bearing and now the dryer is dead! i reversed the wires on the door switch and it made no difference. then, the switch fell apart on me! this is a 11 yr old frig electric FDE436RES1. (the bearing job not too bad, btw, thanks guys!) can i somehow bypass the switch to see if that's the problem? could i have bumped/disconnected something messing with the bearing? sigh.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire electric dryer GaydosBlessed Dryer Repair 3 06-27-2009 05:05 AM
Frigidaire Electric Dryer Not Heating tleelee Dryer Repair 2 03-31-2009 01:59 PM
frigidaire electric dryer mod#gleq2152eso whirpguy Dryer Repair 0 02-05-2009 02:11 PM
frigidaire electric dryer atlanta handyman Dryer Repair 2 11-20-2008 06:21 PM
Frigidaire electric dryer outlaw Dryer Repair 1 01-19-2008 06:42 PM
