Discuss
No heat
 in
Dryer Repair
Replaced part#AP4045859 dried one load and quit heating again. The same part failed again. I've checked all the common items
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No heat
  #1 (permalink)
Old 11-10-2011, 06:38 PM
Junior Member
reporacer40 is on a distinguished road
Default No heat
Model Number: MDE6700AYW   Brand: Maytag   Age: 1 - 5 years
Replaced part#AP4045859 dried one load and quit heating again. The same part failed again. I've checked all the common items and even bypassed the fuse to check the element and it seems to be cycling on for about 5 seconds at a time. You can hear the thermostat click and kill power to the element then after about 30 seconds the element heats back up. Is this cycling of power to element normal or should it stay on for longer period of time? Is it normal for the thermostat on the element heat shield to control the heating cycle or is it controled elsewhere?
Ads By Google
Related Models
Maytag MDE6700AYW Dryer - Ele
Maytag MDE6700AZW Dryer - Ele
Maytag MDE6800AYB Dryer - Ele
Maytag MDE6800AYQ Dryer - Ele
Maytag MDE6800AYW Dryer - Ele
Maytag MDE6800AZQ Dryer - Ele
Maytag MDE6800AZW Dryer - Ele
Maytag MDE7057AYQ Dryer - Ele
Maytag MDE7057AYW Dryer - Ele
Maytag MDE7057AZW Dryer - Ele
Maytag MDE7400AYQ Dryer - Ele
Maytag MDE7400AYW Dryer - Ele
Maytag MDE7400AZQ Dryer - Ele
Maytag MDE7400AZW Dryer - Ele
Maytag MDE7460AYQ Dryer - Ele
Maytag MDE7460AYW Dryer - Ele
Maytag MDE7500AYQ Dryer - Ele
Maytag MDE7500AYW Dryer - Ele
Maytag MDE7500AZQ Dryer - Ele
Maytag MDE7500AZW Dryer - Ele
Maytag MDE7550AGW Dryer - Ele
International MDE7550AGW Dryer - Ele
Maytag MDE7600AUW Dryer - Ele
Maytag MDE7600AYQ Dryer - Ele
Maytag MDE7600AYW Dryer - Ele
Maytag MDE7600AZQ Dryer - Ele
Maytag MDE7600AZW Dryer - Ele
Maytag MDE7657AYQ Dryer - Ele
Maytag MDE7657AYW Dryer - Ele
Maytag MDE7657BYQ Dryer - Ele
Maytag MDE7657BYW Dryer - Ele
Maytag MDE7658AYQ Dryer - Ele
Maytag MDE7658AYW Dryer - Ele
Maytag MDE7658BYQ Dryer - Ele
Maytag MDE7658BYW Dryer - Ele
Maytag MDE7757AYQ Dryer - Ele
Maytag MDE7757AYW Dryer - Ele
Maytag MDE7758AYQ Dryer - Ele
Maytag MDE7758AYW Dryer - Ele
Maytag MDE8000AYQ Dryer - Ele
Maytag MDE8000AYW Dryer - Ele
Maytag MDE8000AZW Dryer - Ele
Maytag MDE8057AYQ Dryer - Ele
Maytag MDE8057AYW Dryer - Ele
Maytag MDE8057AZW Dryer - Ele
Maytag MDE8058AYQ Dryer - Ele
Maytag MDE8058AYW Dryer - Ele
Maytag MDE8400AYQ Dryer - Ele
Maytag MDE8400AYW Dryer - Ele
Maytag MDE8400AZW Dryer - Ele
Maytag MDE8416AYA Dryer - Ele
Maytag MDE8416AYW Dryer - Ele
International MDE8426AAW Dryer - Ele
International MDE8426AGW Dryer - Ele
Maytag MDE8500AYW Dryer - Ele
Maytag MDE8506AYA Dryer - Ele
Maytag MDE8506AYW Dryer - Ele
Maytag MDE8506AZW Dryer - Ele
International MDE8550AGW Dryer - Ele
International MDE8550BGW Dryer - Ele
Maytag MDE8600AYQ Dryer - Ele
Maytag MDE8600AYW Dryer - Ele
Maytag MDE8600AZQ Dryer - Ele
Maytag MDE8600AZW Dryer - Ele
Maytag MDE8757AYQ Dryer - Ele
Maytag MDE8757AYW Dryer - Ele
Maytag MDE9206AYA Dryer - Ele
Maytag MDE9206AYW Dryer - Ele
Maytag MDE9206AZW Dryer - Ele
Maytag MDE9306AUW Dryer - Ele
Maytag MDE9306AYA Dryer - Ele
Maytag MDE9306AYW Dryer - Ele
Maytag MDE9306AZA Dryer - Ele
Maytag MDE9306AZW Dryer - Ele
Maytag MDE9316AYA Dryer - Ele
Maytag MDE9316AYQ Dryer - Ele
Maytag MDE9316AYW Dryer - Ele
Maytag MDE9316AZW Dryer - Ele
Maytag MDE9357AYA Dryer - Ele
Maytag MDE9357AYQ Dryer - Ele
Maytag MDE9357AYW Dryer - Ele
Maytag MDE9360AYW Dryer - Ele
Maytag MDE9390AYW Dryer - Ele
Maytag MDE9390AZW Dryer - Ele
Maytag MDE9420AYW Dryer - Ele
Maytag MDE9420AZW Dryer - Ele
Maytag MDE9520AYQ Dryer - Ele
Maytag MDE9520AYW Dryer - Ele
Maytag MDE9520AZW Dryer - Ele
Maytag MDE9557AYA Dryer - Ele
Maytag MDE9557AYQ Dryer - Ele
Maytag MDE9557AYW Dryer - Ele
Maytag MDE9557AZA Dryer - Ele
Maytag MDE9557AZQ Dryer - Ele
Maytag MDE9557AZW Dryer - Ele
Maytag MDE9606AUW Dryer - Ele
Maytag MDE9606AYA Dryer - Ele
Maytag MDE9606AYQ Dryer - Ele
Maytag MDE9606AYW Dryer - Ele
Maytag MDE9606AZA Dryer - Ele
Maytag MDE9606AZQ Dryer - Ele
Maytag MDE9606AZW Dryer - Ele
Maytag MDE9700AYM Dryer - Ele
Maytag MDE9700AYQ Dryer - Ele
Maytag MDE9700AYW Dryer - Ele
Maytag MDE9700AZM Dryer - Ele
Maytag MDE9700AZW Dryer - Ele
Maytag MDE9706AYA Dryer - Ele
Maytag MDE9706AYW Dryer - Ele
Maytag MDE9706AZW Dryer - Ele
Maytag MDE9766AYW Dryer - Ele
Maytag MDE9766AZW Dryer - Ele
Maytag MDE9800AYQ Dryer - Ele
Maytag MDE9800AYW Dryer - Ele
Maytag MDE9800AZQ Dryer - Ele
Maytag MDE9800AZW Dryer - Ele
Maytag MDE9806AYA Dryer - Ele
Maytag MDE9806AYW Dryer - Ele
Maytag MDE9806AZW Dryer - Ele
Maytag MDE9876AYW Dryer - Ele
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
No High Heat, Medium heat work fine! Scubadude Dryer Repair 0 09-07-2010 05:39 PM
Dryer stops after a few minutes with heat on - will run continuously with heat off somegeek Dryer Repair 0 05-27-2010 01:35 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
