| » No heat |
Model Number: LER463EQ0 Brand: Whirlpool Age: 5 - 10 years
It runs but the element will not heat up. I have checked the thermal fuse and it is fine. I Have power going to the heating element as well as coming back out, so I have continuity in the element. I also checked to make sure that I have 110 volts on both legs where the cord connects to the dryer. I am pretty mechanically inclkined, but....this one has me stumped. I figure if there is power to the element, then I should be working!
| Display Modes | |
| Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat | dsumption | Oven Repair (including Ranges and Cooktops) | 3 | 04-04-2011 05:03 PM |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| No High Heat, Medium heat work fine! | Scubadude | Dryer Repair | 0 | 09-07-2010 05:39 PM |
| Dryer stops after a few minutes with heat on - will run continuously with heat off | somegeek | Dryer Repair | 0 | 05-27-2010 01:35 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
