| » Dryer wont come on |
Model Number: LER7646EZ1 Brand: Whirlpool Age: More than 10 years
Push start,
timer ticks dryer wont start door loght comes on when door is open |
first thing to check is that there is 240 volts going to the dryer.. Check your 2 fuses or breakers at your electrical panel. If ok there could be a therminal fuse that open, this is found in the back of the dryer,you have to take the back cover off to check [pull plug first] .IF ok check the door switch, should make a clicking noise..
__________________
| Display Modes | |
| dryer wont start | phyllis | Dryer Repair | 5 | 10-21-2008 03:24 PM |
| Dryer wont heat | retcsgt | Dryer Repair | 0 | 10-29-2007 04:51 AM |
| Dryer wont heat | TomK | Dryer Repair | 0 | 10-28-2007 12:47 AM |
| dryer wont start | debbie | Dryer Repair | 3 | 10-14-2007 04:40 AM |
| dryer wont heat | tom46151 | Dryer Repair | 1 | 09-10-2007 06:56 AM |
