| » Dryer Heats for 5-10 minutes then heat shuts off |
Model Number: LGN2000JQ2 Brand: Whirlpool Age: 5 - 10 years
The dryer will heat up and run for anytime between 5-10 minutes, then the heat/burner will shut off, but the drum continues to turn and will blow out cold air.
We have checked continuity on the Thermal fuse it seems to have continuity. We checked the cycling thermostat, it has four leads. The top on bottom leads have continuity but the two side leads do not have continuity. Is this correct? We also check the gas valve coils but the readings were just above the specifications. Would a high resistance reading cause the flame/heat to shut off? What else could we check to resolve this issue? Thanks, Marlin Ads By Google Related Models Last edited by mgutting : 11-09-2011 at 06:02 PM. |
| Display Modes | |
| Gas dryer lights/heats, then heat shuts off | cantin | Oven Repair (including Ranges and Cooktops) | 0 | 08-22-2011 02:10 PM |
| maytag dryer ignites,heats for 2 minutes then shuts down & wont re-ignite | brhandyman | Dryer Repair | 0 | 09-16-2010 01:45 PM |
| Dryer Heats up for about 8 minutes then flame shuts off | Michael McBride | Dryer Repair | 1 | 05-18-2010 04:39 AM |
| Gas dryer heats up for a couple minutes then no heat + gas smell | keithk78 | Dryer Repair | 2 | 10-19-2009 08:29 PM |
| Dryer heats for a few minutes then no heat | BLysek | Dryer Repair | 3 | 01-31-2009 05:55 AM |
