| » Stained Dryer |
You have to find a solvent that works with what sounds like ink.
Start with soap and water THEN Isopropyl alcohol THEN Varsol (minerals spirits) use the odorless type. It will cut back on the stink. What ever you use, use it sparingly. The last 2 are flammable so be careful you do not want to start a fire. After cleaning leave the door open overnight to get rid of most of the fumes. Then run it on air only to be sure it is solvent free. Then low heat and then high heat. You did not say if it was gas or electric, gas of coarse increases the danger. Note you may have to pull the unit apart to properly clean it. Also if you use a solvent try not to get it on the felt drum seals. With Varsol it would not be a bad idea to also use soap and water to get rid of any residue inside the drum.
__________________
| Display Modes | |
| stained glass on microwave door | rideblackgeym | Microwave Repair | 0 | 01-29-2010 11:44 AM |
| Rust stained collars and cuffs | dryer_in_den | Dryer Repair | 0 | 06-15-2009 10:24 AM |
