Discuss
Dryer overheat blowing thermal fuse heater box, not vent fuse
 in
Dryer Repair
The other day my wife told me the dryer didnt' appear to be working right - wasn't heating up. After
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer overheat blowing thermal fuse heater box, not vent fuse
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-08-2011, 10:52 AM
Junior Member
try2repairguy is on a distinguished road
Default Dryer overheat blowing thermal fuse heater box, not vent fuse
Model Number: LE572OXSW0   Brand: Whirlpool   Age: More than 10 years
The other day my wife told me the dryer didnt' appear to be working right - wasn't heating up. After some research, I figured out that the thermal circuit fuse that is mounted to the upper portion of the heater box was no good. Testing continuity across the legs on this component showed an open circuit (full resistance). After replacing (can't purchase separately btw - comes paired with the t-stat mounted to the lower portion of the heater box), the dryer worked again. I watched as the heater element coils lit up and glowed. I also cleared whatever obstruction I could re; vent system since I'd heard this is usually the culprit of an overheat condition with dryers.
Confident that I had fixed the problem, I put everything back together. However, the fuse didn't last through a complete dry cycle. Cold again with damp clothes (no drying) :-( That was yesterday.
Trying to wrap my arms around how everything works and how the vent system is crucial to proper operation that prevents overheating. What puzzles me is, if I temporarily jump the wires that are connected to this (now) bad fuse, the heat elements glow (normal since that's what is supposed to happen). After the dryer reaches what I perceive to be operating temperature, the t-stat trips and the elements shut off. That said, now the dryer starts drawing cooler air through which should, for all intents and purposes, cool the dryer. Why would it matter if there is a restriction in the venting system if the coils on the heating element are turning on and off with the t-stat? And why or how, if that is the case, would the therm. switch keep blowing?
Thanks!
Related Models
Whirlpool LE5750XKW0 Residential Dryer
Whirlpool LE5750XKW1 Residential Dryer
Whirlpool LE5750XKW2 Residential Dryer
Whirlpool LE5750XMW0 Residential Dryer
Whirlpool LE5750XMW1 Residential Dryer
Whirlpool LE5760XSW0 Residential Dryer
Whirlpool LE5760XSW1 Residential Dryer
Whirlpool LE5770XWW0 Residential Dryer
Whirlpool LE5780XKW0 Residential Dryer
Whirlpool LE5780XKW1 Residential Dryer
Whirlpool LE5780XMW0 Residential Dryer
Whirlpool LE5780XMW1 Residential Dryer
Whirlpool LE5780XMW2 Residential Dryer
Whirlpool LE5790XMW0 Residential Dryer
Whirlpool LE5790XMW1 Residential Dryer
Whirlpool LE5790XPW0 Residential Dryer
Whirlpool LE5790XSW0 Residential Dryer
Whirlpool LE5790XSW1 Residential Dryer
Whirlpool LE5795XMW0 Residential Dryer
Whirlpool LE5795XPW0 Residential Dryer
Whirlpool LE5795XPW1 Residential Dryer
Whirlpool LE5800XKW0 DRYER
Whirlpool LE5800XKW1 Residential Dryer
Whirlpool LE5800XMW0 Residential Dryer
Whirlpool LE5800XMW1 Residential Dryer
Whirlpool LE5800XMW2 Residential Dryer
Whirlpool LE5800XPW0 Residential Dryer
Whirlpool LE5800XPW1 Residential Dryer
Whirlpool LE5800XSN3 ELECTRIC DRYER
Whirlpool LE5800XSW0 Residential Dryer
Whirlpool LE5800XSW1 Residential Dryer
Whirlpool LE5800XSW2 Residential Dryer
Whirlpool LE5800XSW3 Residential Dryer
Whirlpool LE5805XPW0 Residential Dryer
Whirlpool LE5810XPW0 Residential Dryer
Whirlpool LE5900XSW0 Residential Dryer
Whirlpool LE5920XKW0 Residential Dryer
Whirlpool LE5920XKW1 Residential Dryer
Whirlpool LE5920XMW0 Residential Dryer
Whirlpool LE5920XMW1 Residential Dryer
Whirlpool LE5920XMW2 Residential Dryer
Whirlpool LE5950XSW0 Residential Dryer
Frigidaire LE600AXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600AXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD3 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXW3 Wwh(v1) / 27 " Laundry Center
Whirlpool LE6055XSW0 Residential Dryer
Whirlpool LE6055XSW1 Residential Dryer
Whirlpool LE6090XSW0 Residential Dryer
Whirlpool LE6090XSW1 Residential Dryer
Whirlpool LE6090XTW0 Residential Dryer
Whirlpool LE6098XSW0 Residential Dryer
Whirlpool LE6098XSW1 Residential Dryer
Whirlpool LE6098XTW0 Residential Dryer
Whirlpool LE6098XTW1 Residential Dryer
Whirlpool LE6100XSW0 Residential Dryer
Whirlpool LE6150XSW0 Residential Dryer
Whirlpool LE6150XSW1 Residential Dryer
Whirlpool LE6400XKW0 Residential Dryer
Whirlpool LE6400XPW0 Residential Dryer
Whirlpool LE6400XSW0 Residential Dryer
Whirlpool LE6405XPW0 Residential Dryer
Whirlpool LE6600XPW0 Residential Dryer
Whirlpool LE6600XSW0 Residential Dryer
Whirlpool LE6605XPW0 Residential Dryer
Whirlpool LE6605XPW1 Residential Dryer
Whirlpool LE6680XPW0 Residential Dryer
Whirlpool LE6680XSW0 Residential Dryer
Whirlpool LE6685XPW0 Residential Dryer
Whirlpool LE6685XPW1 Residential Dryer
Whirlpool LE6800XPW0 Residential Dryer
Whirlpool LE6800XSW0 Residential Dryer
Whirlpool LE6800XTG0
Whirlpool LE6800XTN0
Whirlpool LE6800XTW0 Residential Dryer
Whirlpool LE6805XPW0 Residential Dryer
Whirlpool LE6810XPW0 Residential Dryer
Whirlpool LE6810XSW0 Residential Dryer
Whirlpool LE6880XSW0 Residential Dryer
Whirlpool LE6880XSW1 Residential Dryer
Whirlpool LE6880XTW0 Residential Dryer
Whirlpool LE6880XTW1 Residential Dryer
Whirlpool LE7000XMW0 Residential Dryer
Whirlpool LE7000XMW1 Residential Dryer
Whirlpool LE7000XMW2 Residential Dryer
Whirlpool LE7000XPW0 Residential Dryer
Whirlpool LE7000XSW0 Residential Dryer
Whirlpool LE7000XTG0
Whirlpool LE7000XTN0
Whirlpool LE7000XTW0 Residential Dryer
Whirlpool LE7005XPW0 Residential Dryer
Whirlpool LE7010XPW0 Residential Dryer
Whirlpool LE7010XSW0 Residential Dryer
Whirlpool LE7080XSW0 Residential Dryer
Whirlpool LE7080XSW1 Residential Dryer
Whirlpool LE7080XTW0 Residential Dryer
Whirlpool LE7080XTW1 Residential Dryer
Amana LE7101LB DRYER- ELE
Amana LE7101WB DRYER- ELE
Amana LE7111LB DRYER- ELE
Amana LE7111LM DRYER- ELE
Amana LE7111WB DRYER- ELE
Amana LE7111WM DRYER- ELE
Amana LE7121LM DRYER- ELE
Amana LE7121WM DRYER- ELE
Amana LE7153LB DRYER- ELE
Amana LE7153LM DRYER- ELE
Amana LE7153WB DRYER- ELE
Amana LE7153WM DRYER- ELE
Amana LE7163LM DRYER- ELE
Amana LE7163WM DRYER- ELE
Whirlpool LE7680XMW0 Residential Dryer
Whirlpool LE7680XPW0 Residential Dryer
Whirlpool LE7680XSW0 Residential Dryer
  #2 (permalink)
Old 11-08-2011, 07:17 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL LE5720XSW0 Residential Dryer | AppliancePartsPros.com
See the attachment for a wiring diagram. I could not find a XSW0 so diagram is for a XSW1 which should be close it not the same.
The cycling thermostat is on the blower assembly and you are blowing the thermal cutout on the heater assembly basically you are measuring the temperature in a different temperature zone so that can cause problems. As an example lets say room air is being sucked into the air flow path before the cycling thermostat, it sees a cooler temperature so turns off when the heater is hotter than it should be. Plus there are other possibilities.
It all depends when they turn on/off. Also usually it is the thermal fuse that blows when there is a vent restriction.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
In your case it could be that it has failed in such a way that the thermostat can control it but it is putting out too much heat on a short piece of the element and pooping the ther,mal cutout.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening at the correct temperature.
__________________
  #3 (permalink)
Old 11-10-2011, 08:27 AM
Junior Member
Default
Thanks, denman.
After tearing down the vent system and cleaning out thoroughly - lint chute, blower motor, vent hose leading out the side of the house, checked lint screen, and the bulkhead opening that feeds to the lint chute (can be seen from inside the drum through door on the upper right of the bulkhead), I replaced the fuse again and it seemed to do the trick.
Heating elements turn on and off with the t-stat as expected and the dryer doesn't seem to overheat any more.
Looks like a good fix. Thanks again.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer thermal fuse blowing gregorybo Dryer Repair 0 07-19-2011 05:33 PM
dryer blowing thermal fuse on heating element kents12 Dryer Repair 6 05-25-2011 05:25 AM
maytag dryer blowing thermal fuse chavez107 Dryer Repair 2 04-20-2010 02:10 AM
Dryer thermal fuse keeps blowing pocketpet3500 Dryer Repair 3 08-19-2009 05:26 PM
Whirlpool dryer-thermal fuse keeps blowing needs help Dryer Repair 4 04-13-2009 03:48 PM
