Discuss
Squeaky Dryer
 in
Dryer Repair
I own a 9yr. old front loading Kenmore Gas Dryer, model 417.90042990 that has started to squeak. I believe
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Squeaky Dryer
  #1 (permalink)
Old 05-20-2009, 08:21 PM
fiorillo fiorillo is offline
Junior Member
fiorillo is on a distinguished road
Default Squeaky Dryer
Model Number: 417.90042990   Brand: Kenmore   Age: 5 - 10 years
I own a 9yr. old front loading Kenmore Gas Dryer, model 417.90042990 that has started to squeak. I believe it is the belt but I am not sure. I sprayed some automotive belt dressing on the belt and that did not fix the problem. The belt appears to be glazed over and somewhat discolored which is probably normal for a 9yr. old dryer. How difficult is a belt replacement on this model?
Related Models
Kenmore 417.90042990  DRYER
Kenmore 417.90042991  DRYER
Kenmore 417.90052990  DRYER
Kenmore 417.90052991  DRYER
Kenmore 417.90142000  DRYER
Kenmore 417.90802990  LAUNDRY CENTER
Kenmore 417.90802991  LAUNDRY CENTER
Kenmore 417.90802992  LAUNDRY CENTER
Kenmore 417.90807990  LAUNDRY CENTER
Kenmore 417.90812990  LAUNDRY CENTER
Kenmore 417.90812991  LAUNDRY CENTER
Kenmore 417.90812992  LAUNDRY CENTER
Kenmore 417.90814000  LAUNDRY CENTER
Kenmore 417.90814001  LAUNDRY CENTER
Kenmore 417.90814002  LAUNDRY CENTER
Kenmore 417.90817990  LAUNDRY CENTER
Kenmore 417.90862990  LAUNDRY CENTER
Kenmore 417.90862991  LAUNDRY CENTER
Kenmore 417.90862992  LAUNDRY CENTER
Kenmore 417.90872990  LAUNDRY CENTER
Kenmore 417.90872991  LAUNDRY CENTER
Kenmore 417.90872992  LAUNDRY CENTER
Kenmore 417.91042000  DRYER
Kenmore 417.91042001  DRYER
Kenmore 417.91052000  GAS DRYER
Kenmore 417.91052001  DRYER
Kenmore 417.91142000  DRYER
Kenmore 417.91142001  DRYER
Kenmore 417.91702000  LAUNDRY CENTER
Kenmore 417.91702001  LAUNDRY CENTER
Kenmore 417.92042100  DRYER
Kenmore 417.92042101  DRYER
Kenmore 417.92042102  SEARS/GAS DRYER
Kenmore 417.92052101  DRYER
Kenmore 417.92052102  DRYER
Kenmore 417.92052103  SEARS/GAS DRYER
Kenmore 417.92142100  DRYER
Kenmore 417.92142101  DRYER
Kenmore 417.92142102  SEARS/GAS DRYER
Kenmore 417.92702200  LAUNDRY CENTER
Kenmore 417.93042200  SEARS/DRYER
Kenmore 417.93042201  SEARS/DRYER
Kenmore 417.93052200  SEARS/DRYER
Kenmore 417.93052201  SEARS/DRYER
Kenmore 417.93142200  SEARS/DRYER
Kenmore 417.93142201  SEARS/DRYER
Kenmore 417.93702200  LAUNDRY CENTER
Kenmore 417.93802200  LAUNDRY CENTER
Frigidaire 41739012890 Frg(v0) / Washer
Frigidaire 41739012891
Frigidaire 41739022890 Frg(v0) / Washer
Frigidaire 41739022891 Frg/washer
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
Kenmore 41789195110 COMBINATION WASHER/DRYER
Kenmore 41789195120 COMBINATION WASHER/DRYER
Kenmore 41789195600 COMBINATION WASHER/DRYER
Kenmore 41789195610 COMBINATION WASHER/DRYER
Kenmore 41789195620 COMBINATION WASHER/DRYER
Kenmore 41789195800 COMBINATION WASHER/DRYER
Kenmore 41789195810 COMBINATION WASHER/DRYER
Kenmore 41789195820 COMBINATION WASHER/DRYER
Kenmore 41789390100 COMBINATION WASHER/DRYER
Kenmore 41789390101 COMB, WASHER/DRYER
Kenmore 41789390110 COMBINATION WASHER/DRYER
Kenmore 41789390600 COMBINATION WASHER/DRYER
Kenmore 41789390700 COMBINATION WASHER/DRYER
Kenmore 41789390701 COMB, WASHER/DRYER
Kenmore 41789390710 COMBINATION WASHER/DRYER
Kenmore 41789390800 COMBINATION WASHER/DRYER
Kenmore 41789390801 COMB, WASHER/DRYER
Kenmore 41789390810 COMBINATION WASHER/DRYER
Kenmore 41789395100 WASHER-DRYER
Kenmore 41789395101 COMBINATION WASHER/DRYER
Kenmore 41789395110 COMBINATION WASHER/DRYER
Kenmore 41789395600 WASHER-DRYER
Kenmore 41789395701 COMBINATION WASHER/DRYER
Kenmore 41789395710 COMBINATION WASHER/DRYER
Kenmore 41789395800 WASHER-DRYER
Kenmore 41789395801 COMBINATION WASHER/DRYER
Kenmore 41793042202 DRYER
Kenmore 41793052202 DRYER
Kenmore 41793142202 DRYER
Kenmore 41793702201 SEARS/LAUNDRY CENTER
Kenmore 41793802201 LAUNDRY CENTER
Kenmore 41793812200 LAUNDRY CENTER
Kenmore 41793812201 LAUNDRY CENTER
Kenmore 41793814200 LAUNDRY CENTER
Kenmore 41793814201 LAUNDRY CENTER
Kenmore 41793862200 LAUNDRY CENTER
Kenmore 41793862201 LAUNDRY CENTER
Kenmore 41793872200 LAUNDRY CENTER
Kenmore 41793872201 LAUNDRY CENTER
Kenmore 41794802300 LAUNDRY CENTER
Kenmore 41794802301 LAUNDRY CENTER
Kenmore 41794812300 LAUNDRY CENTER
Kenmore 41794812301 LAUNDRY CENTER
Kenmore 41794814300 LAUNDRY CENTER
Kenmore 41794814301 LAUNDRY CENTER
Kenmore 41794862300 LAUNDRY CENTER
Kenmore 41794862301 SEARS/LAUNDRY CENTER
Kenmore 41794872300 LAUNDRY CENTER
Kenmore 41794872301 SEARS/LAUNDRY CENTER
Kenmore 41794988101 AUTOMATIC WASHER
Kenmore 41794988110 AUTOMATIC WASHER
Kenmore 41794988801 AUTOMATIC WASHER
  #2 (permalink)
Old 05-21-2009, 06:14 AM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
replace the roller, the idler pully and the belt. they all come in one kit. it is cheap, and the way to go. i do it everyday. tom
  #3 (permalink)
Old 05-21-2009, 07:16 AM
Junior Member
Excellent thanks for the tip. Is this a quick repair? Or should I ask how long does it take an experienced tech. like yourself?
  #4 (permalink)
Old 05-21-2009, 07:21 AM
Senior Expert
APP Volunteer
Default
it takes me about 10 minutes. Top comes up, and the front comes off. Release the belt, and remove the drum, and you are there. Tom ApplianceEducator.com
  #5 (permalink)
Old 05-21-2009, 07:28 AM
Junior Member
Thanks for the information.
  #6 (permalink)
Old 05-23-2009, 10:58 AM
Junior Member
The top popped right off, however I don't see how the front comes off, and the drum to get the belt off? Any idea where I can find an illustrated parts breakdown showing everything for this Kenmore front load dryer?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
squeaky dryer liang Dryer Repair 2 04-21-2009 07:27 PM
squeaky dryer swthrtaj Dryer Repair 1 12-12-2008 03:16 PM
GE Dryer squeaky ckadaja Dryer Repair 1 01-02-2008 04:42 AM
squeaky dryer maytag97l Dryer Repair 1 09-30-2007 03:41 AM
Squeaky Dryer Eliz17 Dryer Repair 1 09-24-2007 03:34 PM
