Discuss
Heating Problems
 in
Dryer Repair
I am hoping to get my dryer fixed and that someone will know what the answer is. This is a
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Heating Problems
  #1 (permalink)
Old 12-13-2007, 01:33 PM
Ms. Irish Ms. Irish is offline
Junior Member
Ms. Irish is on a distinguished road
Default Heating Problems
Model Number: 11072822101   Brand: Kenmore   Age: 1 - 5 years
I am hoping to get my dryer fixed and that someone will know what the answer is. This is a Gas Dryer.
Dryer Type: DWSR-NAT-1206006CV22
Dryer will not get very warm. It takes two 80 cycles to get clothes dry and it will be mostly air dried. If you put in clothes for the 20 minute or less cycle they will get warm but not HOT.
I have pulled the dryer from the wall and checked the silver hose for clogs and it is all clean.
A couple of months ago my gas was shut off and since then I have been having troubles. Maybe coincidense? But I did see the gas guy check to see if the thing was lit through the little plug hole.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-14-2007, 12:31 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem with your dryer are a bad coils on the gas valve.
The gas valve coil kit
- The part number for the gas valve coil kit is AP2150379
In order to get access to replace the gas valve coils you have to remove the front panel.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana ref. problems wayfran1 Refrigerator & Freezer Repair 1 06-18-2008 02:02 PM
washer problems grant Washer Repair 2 11-27-2007 06:49 PM
Whirlpool Heating Problems missmia Dishwasher Repair 0 11-09-2007 10:24 AM
Heating problems dharer Oven Repair (including Ranges and Cooktops) 0 08-22-2007 10:00 AM
Dryer Problems rr454 Dryer Repair 4 08-09-2007 11:25 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
