dslmech73
#1 Posted : Monday, May 18, 2009 6:57:11 PM(UTC)
dslmech73
dryer runs but does not have heat. have checked and found that the heating element has no ground. have added a ground wire to the orange wire and the heater element get hot. where does the heater element get its ground from
#2 Posted : Tuesday, May 19, 2009 3:08:49 AM(UTC)
Replacement parts for WHIRLPOOL TEDS740PQ1 | AppliancePartsPros.com
Here is a wiring diagram
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208576793.pdf
It does not have a ground!!!
You are very lucky as you have added a short to the unit and could of had a huge arc & spark.
REMOVE THAT GROUND WIRE ASAP.
The heater runs on 240 volts and is not connected to ground.
Check the Thermal Cutoff, Operating Thermostat, High Limit Thermostat all should be 0 ohms at room temperature.
Also when in a cycle Timer Switch 2 should be closed.
Remove a wire from one side of any device you are measuring to ensure that you are not reading an alternate/parallel circuit path.
One of the above is open for sure as if all were OK you would have a dead short from L1 to ground and of coarse a lot of sparks/flames.
Be sure to unplug the unit when working on it.
