Discuss
Maytag Dryer Not Heating
 in
Dryer Repair
My dryer was not heating. I found the heating element and the jumper wire were "broken" at the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer Not Heating
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-13-2007, 06:45 AM
Jim N Jim N is offline
Junior Member
Jim N is on a distinguished road
Default Maytag Dryer Not Heating
Model Number: LDE7500   Brand: Maytag   Age: More than 10 years
My dryer was not heating. I found the heating element and the jumper wire were "broken" at the terminal. I replaced the complete heater assembly and jumper wire. The dryer will not run at all now. It "hums". Do I have it wired wrong? Is there a wiring diagram somewhere or do i need to replace the high limit thermostat or the fuse?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-13-2007, 09:05 PM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
if you have a second person to help, leave drum door open and have someone depress the start button on control panel, while you depress the door switch and then try to push the paddle / baffle of drum clockwise.. if the drum turns on its own, you are getting / have a bad motor ( hopefully you did not wire anything wrong when you replaced the heater / jumper wires.. )
  #3 (permalink)
Old 12-14-2007, 10:37 AM
Junior Member
Default
No, the motor is OK. If I connect both wires to the same terminal of the heating element, the dryer runs - no heat. I checked continuity thru the stat, the fuse and the heating element.
  #4 (permalink)
Old 12-14-2007, 10:47 AM
Junior Member
Default
Maybe I connected wiring wrong? I connected purple wire from low-limt stat to hi-limt stat; white jumper from hi-limit stat to one heating element terminal; black wire from other heating element terminal to motor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag oven not heating moongidget Oven Repair (including Ranges and Cooktops) 1 02-22-2008 08:05 AM
Maytag dryer not heating. elkski Dryer Repair 2 10-25-2007 11:21 AM
Maytag dryer not heating up on all cycles and not properly drying clothes. radioman464 Dryer Repair 1 10-18-2007 03:48 AM
Maytag - Dryer not heating timer mode freebird Dryer Repair 0 08-16-2007 11:06 AM
dryer not heating vonryansexp Dryer Repair 0 07-24-2007 11:01 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
