| » Maytag Dryer Not Heating |
Model Number: LDE7500 Brand: Maytag Age: More than 10 years
My dryer was not heating. I found the heating element and the jumper wire were "broken" at the terminal. I replaced the complete heater assembly and jumper wire. The dryer will not run at all now. It "hums". Do I have it wired wrong? Is there a wiring diagram somewhere or do i need to replace the high limit thermostat or the fuse?
if you have a second person to help, leave drum door open and have someone depress the start button on control panel, while you depress the door switch and then try to push the paddle / baffle of drum clockwise.. if the drum turns on its own, you are getting / have a bad motor ( hopefully you did not wire anything wrong when you replaced the heater / jumper wires.. )
| Display Modes | |
| Maytag oven not heating | moongidget | Oven Repair (including Ranges and Cooktops) | 1 | 02-22-2008 09:05 AM |
| Maytag dryer not heating. | elkski | Dryer Repair | 2 | 10-25-2007 12:21 PM |
| Maytag dryer not heating up on all cycles and not properly drying clothes. | radioman464 | Dryer Repair | 1 | 10-18-2007 04:48 AM |
| Maytag - Dryer not heating timer mode | freebird | Dryer Repair | 0 | 08-16-2007 12:06 PM |
| dryer not heating | vonryansexp | Dryer Repair | 0 | 07-24-2007 12:01 PM |
