Discuss
Maytag Dryer makes an awful squealing noise
 in
Dryer Repair
Dryer dries great but it makes an awful racquet (squealing Noise). I have replaced the front tumbler seal and it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer makes an awful squealing noise
  #1 (permalink)
Old 05-18-2009, 01:54 PM
Junior Member
cfoley is on a distinguished road
Default Maytag Dryer makes an awful squealing noise
Model Number: MDE9806AYW   Brand: Maytag   Age: 5 - 10 years
Dryer dries great but it makes an awful racquet (squealing Noise). I have replaced the front tumbler seal and it was better for a couple of days and now it is worse than ever. When I had it apart the last time I noticed the belt is fine but I wonder if I should have replaced the rear seal as well and the tumbler wheels. I don't want to just buy parts. I was hoping you could give some insight as to what I need to purchase other than a "new" dryer. Thank you in advance for your input, I appreciate it.
Sincerely,
Cfoley
Ads By Google
Related Models
Maytag MDE9806AYW Dryer - Ele
Maytag MDE9806AZW Dryer - Ele
Maytag MDE9876AYW Dryer - Ele
Maytag MDET236AYW Dryer - Ele
Maytag MDET236AZW Dryer - Ele
Maytag MDET336AYW Dryer - Ele
Maytag MDET336AZW Dryer - Ele
Maytag MDET446AYW Dryer - Ele
Maytag MDET446AZW Dryer - Ele
Maytag MDG100PN1 Dryer - Gas
Maytag MDG100PN1L Dryer - Gas
Maytag MDG100PN1W Dryer - Gas
Maytag MDG10CSAAL Dryer - Gas
Maytag MDG10CSAAW Dryer - Gas
Maytag MDG10CSABL Dryer - Gas
Maytag MDG10CSABW Dryer - Gas
Maytag MDG10CSAGL Dryer - Gas
Maytag MDG10CSAGW Dryer - Gas
Maytag MDG10CSAKL Dryer - Gas
Maytag MDG10CSEGL Dryer - Gas
Maytag MDG10CSEGW Dryer - Gas
Maytag MDG10DAAAL Dryer - Gas
Maytag MDG10DAAAW Dryer - Gas
Maytag MDG10DAABL Dryer - Gas
Maytag MDG10DAABW Dryer - Gas
Maytag MDG10MNAAW Dryer - Gas
International MDG10MNAGW Dryer - Gas
Maytag MDG10MNEGW Dryer - Gas
Maytag MDG10PDAAL Dryer - Gas
Maytag MDG10PDAAW Dryer - Gas
Maytag MDG10PDABL Dryer - Gas
Maytag MDG10PDABW Dryer - Gas
Maytag MDG10PDEGL Dryer - Gas
Maytag MDG10PDEGW Dryer - Gas
Maytag MDG10PRAAW Dryer - Gas
Maytag MDG10PSABW Dryer - Gas
Maytag MDG10PSAGL Dryer - Ele
Maytag MDG10PSAGW Dryer - Ele
Frigidaire MDG116RBW0 Frg(v1) / 27 " Gas Dryer
Frigidaire MDG116RBW1 Frg(v0) / Gas Dryer
Maytag MDG11CSAAL Dryer - Gas
Maytag MDG11CSAAW Dryer - Gas
Maytag MDG11CSABW Dryer - Gas
Maytag MDG11CSAGL Dryer - Gas
Maytag MDG11CSAGW Dryer - Gas
Maytag MDG11CSEGL Dryer - Gas
Maytag MDG11CSEGW Dryer - Gas
Maytag MDG11MNAAW Dryer - Gas
Maytag MDG11MNAGW Dryer - Gas
Maytag MDG11MNEGW Dryer - Gas
Maytag MDG11PDAAL Dryer - Gas
Maytag MDG11PDAAW Dryer - Gas
Maytag MDG11PDABL Dryer - Gas
Maytag MDG11PDABW Dryer - Gas
Maytag MDG11PDAGL Dryer - Gas
Maytag MDG11PDAGW Dryer - Gas
Maytag MDG11PDEGL Dryer - Gas
Maytag MDG11PDEGW Dryer - Gas
Maytag MDG120P1HW Dryer - Gas
Maytag MDG120PHVW Dryer - Gas
Maytag MDG12CSAAL Dryer - Gas
Maytag MDG12CSAAW Dryer - Gas
Maytag MDG12CSABL Dryer - Gas
Maytag MDG12CSABW Dryer - Gas
Maytag MDG12CSAGW Dryer - Gas
Maytag MDG12CSEGW Dryer - Gas
Maytag MDG12MNAAW Dryer - Gas
Maytag MDG12MNAGW Dryer - Gas
Maytag MDG12MNEGW Dryer - Gas
Maytag MDG12PDAAL Dryer - Gas
Maytag MDG12PDAAW Dryer - Gas
Maytag MDG12PDABL Dryer - Gas
Maytag MDG12PDABW Dryer - Gas
Maytag MDG12PDBAL Dryer - Gas
Maytag MDG12PDBAW Dryer - Gas
Maytag MDG12PDBBL Dryer - Gas
Maytag MDG12PDBBW Dryer - Gas
Maytag MDG12PRAAW Dryer - Gas
Maytag MDG12PRBAW Dryer - Gas
Maytag MDG12PRBBW Dryer - Gas
Maytag MDG12PSABW Dryer - Gas
Maytag MDG12PSAGW Dryer - Gas
Maytag MDG12PSBAW Dryer - Gas
Maytag MDG12PSBBW Dryer - Gas
Maytag MDG13CSAAL Dryer - Gas
Maytag MDG13CSAAW Dryer - Gas
Maytag MDG13CSABW Dryer - Gas
Maytag MDG13CSAGW Dryer - Gas
Maytag MDG13CSAKL Dryer - Gas
Maytag MDG13CSEGW Dryer - Gas
Maytag MDG13MNAAW Dryer - Gas
Maytag MDG13PDAAL Dryer - Gas
Maytag MDG13PDAAW Dryer - Gas
Maytag MDG13PDABL Dryer - Gas
Maytag MDG13PDABW Dryer - Gas
Maytag MDG13PDAGW Dryer - Gas
Maytag MDG13PDBAL Dryer - Gas
Maytag MDG13PDBAW Dryer - Gas
Maytag MDG13PDBBL Dryer - Gas
Maytag MDG13PDBBW Dryer - Gas
Maytag MDG13PDEGW Dryer - Gas
Maytag MDG13PRAAW Dryer - Gas
Maytag MDG13PRBAW Dryer - Gas
Maytag MDG14PDAAL Dryer - Gas
Maytag MDG14PDAAQ Dryer - Gas
Maytag MDG14PDAAW Dryer - Gas
Maytag MDG14PDAEW Dryer - Gas
Maytag MDG14PDAGW Dryer - Gas
Maytag MDG14PDSAW Dryer - Gas
Maytag MDG14PNAEW Dryer - Gas
Maytag MDG14PNAGW Dryer - Gas
Maytag MDG14PNAWW Dryer - Gas
Maytag MDG14PNSAW Dryer - Gas
Maytag MDG14PRAWW Dryer - Gas
Maytag MDG14PRAXW Dryer - Gas
Maytag MDG14PSABW Dryer - Gas
Maytag MDG14PSAGW Dryer - Gas
Maytag MDG16CSAEW Dryer - Gas
Maytag MDG16CSAGW Dryer - Gas
Maytag MDG16CSAKA Dryer - Gas
  #2 (permalink)
Old 05-19-2009, 05:24 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for MAYTAG MDE9806AYW | AppliancePartsPros.com
You will have to try and find the location (back, front etc) of the squeal which sometimes can be very difficult. Sometimes the frequency is a help if it high pitched this is usually from something that is moving fast like the motor or the idler wheel or the blower wheel. Mid frequency the rear rollers. Lower frequency the rear drum glides.
When you changed the seal did you check the front glides for wear?
Did you spin the motor with the belt off? If it squeaks, it will squeal when running.
Check the idler and rear rollers, bearings and shafts for wear.
If OK clean them and put a drop of oil on them.
__________________
  #3 (permalink)
Old 05-19-2009, 06:58 AM
Junior Member
Default Only make Squeal under load
Thanks for getting back to me. The dryer runs great and does not make any noise when running empty. When I had it apart to replace the front seal I put a shot of WD40 on the rear wheels, which was probably a mistake. When a load of wet towels or sheets are put in the dryer that is when the terrible squeal starts and is almost unbearable. I hope that information helps as it is almost impossible to tell you where the squeal is coming from. It is so loud that it resonates throughout the machine. I'm thinking rear wheels and bearings but then I did not know about the "guides you mentioned. Thanks again for your help and I look forward to your reply.
Cfoley
  #4 (permalink)
Old 05-19-2009, 08:13 AM
Senior Expert
APP Volunteer
Default
Cannot be of much more help.
If the WD40 did quiet it down for a while and you only put it on the rear wheels then they would be a prime suspect.
FYI WD40 is a crappy lubricant better off with 3in1 or any straight oil.
__________________
  #5 (permalink)
Old 05-19-2009, 10:50 AM
Junior Member
Default Drum wheels
That is what I was thinking as far as the wheels go. Should I replace the bearings also?
Thanks,
Cfoley
  #6 (permalink)
Old 05-19-2009, 11:49 AM
Senior Expert
APP Volunteer
Default
The bearing is part of the roller, see Item 24 in the "Tumbler" section.
Just check the shafts and the front/back washers to make sure they are not worn.
You will need a pair of Cir (sir) clip pliers to remove the retaining clips.
I would catch up on the wash and then open it up check everything then get the parts and do it all at once.
Also a good idea to clean/check the blower wheel and your vent system.
__________________
  #7 (permalink)
Old 05-19-2009, 12:26 PM
Junior Member
Default Thanks
Opened it up and ordered 2 rollers and 1 shaft, the other one is fine, along with a belt. Thanks again for all your input I appreciate it.
Sincerely,
Cfoley
  #8 (permalink)
Old 05-19-2009, 12:28 PM
Senior Expert
APP Volunteer
Default
My pleasure
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer makes loud squealing for a few minutes on start up bberbe Dryer Repair 3 07-17-2010 12:37 PM
microwave makes loud noise & awful smell mak101376 Microwave Repair 0 01-12-2010 08:15 AM
Maytag stackable washer dryer makes rattling noise anniesmomrocks Dryer Repair 6 08-06-2009 09:15 AM
Squealing noise from Signature 2000 electric dryer saumila Dryer Repair 1 02-14-2008 03:57 PM
whirlpool gas dryer - awful noise jewels Dryer Repair 1 07-29-2007 07:51 PM
