Hi my Kenmore dryer is not working properly, it's blowing cold air instead of heat, as a result my wet cloths are not drying as it should.
Originally Posted by: Desada50 Hi my Kenmore dryer is not working properly, it's blowing cold air instead of heat, as a result my wet clothes are not drying as it should.I would like an urgent resolution to this problem, because the need for a working dryer in my house cannot be valued.
Your model number seems to be missing 3 digits from the front. Kenmore numbers are usually 3 digits, a period and then 8 digits.
The first 3 designate who made the unit. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: Desada50 Originally Posted by: Desada50 Hi my Kenmore dryer is not working properly, it's blowing cold air instead of heat, as a result my wet clothes are not drying as it should.I would like an urgent resolution to this problem, because the need for a working dryer in my house cannot be valued. Desada, First, check and make sure both circuit breakers in the breaker box are set and locked, so you have 240 VAC to the outlet and dryer. You will need to unplug the power cord, or remove power to the dryer, disconnect the exhaust, slide the dryer away from the wll and remove the back panel from the dryer. in the right lower area of the cabinet , you'll find the thermal fuse, high limit switch and the heater element tunnel, you'll need to cheack for damaged wires, broken element, or open thermal fuse or thermostat. Thanks and Good Luck, :) :) :)
