We have an older Kenmore dryer. It will not start when you push the start button. The timer clicks on, but the dryer will not start. I thought it was the switch, so I replaced it, but no results. Any thoughts?
First try flipping the breaker off then on a couple times. If that doesn't work, check the door switch. Let us know what you find.
Originally Posted by: magician59 First try flipping the breaker off then on a couple times. If that doesn't work, check the door switch. Let us know what you find. That does not seem to do any good. Anything else I might try?
