| » Maytag ELEC Dryer No Heat |
Model Number: MDE8600AYW Brand: Maytag Age: 1 - 5 years
Hi does any one have a clue to what I should look at Next ?
I have a 4 yr old Maytag electric dryer MDE8600AYW It stopped blowing heat. It runs truns blower works strong but no Heat ! I checked the Hight Limit Thermostat and Thermal Fuse it showd ok but I replaced both of them any way. It did not do the trick still nothing !! I tested and inspected the Heat Element all is ok no cracks or burns or ground outs.The outlet puts out 210V So any Clue to what I missed to get this Dryer back in the Heat ??? Thanks in advance for the help. Bob Ads By Google Related Models |
Thanks I have recheck the Thermal fuse 4 motor run its ok and blower runs. I checked the cyling thermostat the end concetion is open the center is closed.
I think thats the way is should be ???? As far as checking the input to the Element not clear on how to do so ? You said un plug wire connect tester to lead wire then should I put the other half of tested to element lead to complete the circut ? Sorry for the dumb ?? live electric is the only thing that maked me dot all my I's and cross all T's first. |
Quote:
1. unplug the dryer. 2. unplug one wire from the element. 3. plug one of the meter leads to that wire. and the other meter lead to ground. 4. turn the dryer on and see if there is 120 volts. Repeat on the other side if the first one is good. There should be one side missing power. Once you locate which side is missing power. Follow that wire to the next part and test it. If it goes to the motor then chances are the motor switch is the problem. If it goes to the safeties check them again and then go further which will probably end up being the timer. Always test for power with one wire off because you can get 120 volts from either side and so if all wires are plugged you will get 120 volts even if it's not coming from the wire you are testing.
__________________
An appliance tech from a small business. Very busy.. But will try to help when possible. If you would like to visit my home check out this link. ftatalk.com/forumdisplay.php?f=1521 |
Thanks for the help.. yes one lead was dead it goes the the 2 thermostats ( multi temp , ultra care ) pop them off its runs good the other leads on the stats were dead I am not shure if there grounds I guess not .. one goes up to the control switch for low temp the other to that dam motor switch so I do think your correct.
| Display Modes | |
| Maytag Elec Dryer no power | JohnGoubeaux | Dryer Repair | 9 | 07-19-2011 03:07 PM |
| Whirlpool Elec Dryer wont heat up | Canute | Dryer Repair | 8 | 02-26-2010 03:06 AM |
| partial heat for elec dryer | tfd135 | Dryer Repair | 1 | 11-23-2009 06:23 AM |
| Maytag Elec. Dryer Runs but won't heat | pacomt | Dryer Repair | 3 | 01-02-2009 05:42 AM |
| HELP !! Maytag elec. dryer wiring problem | greavuj | Dryer Repair | 0 | 02-25-2008 11:22 AM |
