| » centrifical switch |
Model Number: fdeb34rgso Brand: Frigidaire Age: 5 - 10 years
My electric dryer heating element continues to heat after the motor has stopped. It is my understanding that this is caused by a faulty centrifical switch which should open the electrical path to the element when the motor is idled. In viewing the electrical schematic I do not see an external switch, however, within the motor it appears two switches are present. The m1 and m2 terminals appear to be connected to the element. Is this a replaceable? Or must the motor be replaced?
__________________
I should have thought of that, sometimes I must be wide asleep.
Jim's suggestion is a high probability, because if the heater was on full with no air movement it should blow the thermal fuse.
__________________
| Display Modes | |
| infinite switch wiring change from 6 wires to 5 wire switch | wiedemanndds | Oven Repair (including Ranges and Cooktops) | 5 | 11-24-2009 02:14 PM |
| Dual switch to single switch substitution | jcsimonich | Oven Repair (including Ranges and Cooktops) | 0 | 11-09-2009 05:11 PM |
| GE Cooktop - Heat Switch + Select Switch | dtshenoy | Oven Repair (including Ranges and Cooktops) | 3 | 06-06-2009 03:14 PM |
| cycle switch or motor switch fails | andygregg | Washer Repair | 2 | 01-28-2009 10:25 AM |
