| » Dryer does not turn has power to plug and unit |
Model Number: KEYS850JQ0 Brand: Kitchen Aid Age: 1 - 5 years
I checked for power at the wall plug everything good there, I checked for power at the dryer end everything good there. I can turn on the timer and it is working but unit will not start when I it hit the start button.
Replacement parts for WHIRLPOOL KEYS850JQ0 | AppliancePartsPros.com Here is a wiring diagram https://www.servicematters.com/docs/...%203406681.pdf Could be the door switch, the push-to-start relay or the temp fuse. Fuse is Item 6 in Section 3, mounted to the back of the blower. Unplug the unit, unplug one wire going to the fuse and check the fuse for continuity. Since you checked power I am assuming you have a meter. Replace it as it is a critical safety device. If it is blown clean the interior of the machine including the blower wheel. Also clean and check your vent system. These are the most common causes for it blowing though there are others.
__________________
I want to say thank you denman for your help, as per your advise I replaced the temp fuse and my dryer is now repaired. This was my first time on this forum and it works great. Parts were easy top order, shipped timley and the response's were quick. I know I saved hundreds of dollars by using this forum, again thanks for everyones help!
| Display Modes | |
| New Small Black Plug for Back of Portable AC Unit | enicolers | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 04-30-2010 09:02 AM |
| can not turn off unit | art augustensen | Garbage Disposer Repair | 0 | 04-27-2009 03:15 PM |
| Unit does not power up/run | Trophyhusband | Dishwasher Repair | 5 | 04-24-2009 12:07 PM |
| Convert Kitchen Aid Dryer from 3 Prong Plug to 4 Prong Plug | edd225 | Dryer Repair | 2 | 04-16-2009 06:59 PM |
| No power to Dryer but Have 240 at plug?? | bigredcherokee | Dryer Repair | 3 | 04-16-2009 11:11 AM |
