Discuss
wirlpool dryer
 in
Dryer Repair
Dryer is not completly drying clothes. It look like the heating element does not stay on long enough in the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » wirlpool dryer
  #1 (permalink)
Old 12-12-2007, 04:01 PM
roger roger is offline
Junior Member
roger is on a distinguished road
Default wirlpool dryer
Model Number: ler7646awi   Brand: Whirlpool   Age: More than 10 years
Dryer is not completly drying clothes. It look like the heating element does not stay on long enough in the cycle to dry, seems to cut out too early. What do I replace, heat sensor or something else
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-12-2007, 06:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would do is to take the dryer apart from the front and from the back and clean it. Especially the air duct on the back (#1 on the bulkhead break down diagram) and the blower wheel (#10 on the same break down diagram). Lubricate all drum support rollers (#44 on the same break down diagram).
Assemble the dryer back, disconnect the vent hose from the dryer and run one or two loads. Reconnect the vent hose and run the dryer again.
If without the hose it works better then the vent inside walls is clogged and needs cleaning.
Post your findings, please.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
