| » Roper Dryer |
Model Number: RED4440VQ1 Brand: Roper Age: 5 - 10 years
Roper 4440VQ1 will not start. I followed advice on this site and tested the continuity of the termal fuse, starter swicth, door switch and all were fine. I did not see instructions on how to test the timer?? Other than this, what else is there for me to test??
Replacement parts for WHIRLPOOL RED4440VQ1 29"ELECTRIC DRYER | AppliancePartsPros.com See the attachment for the tech sheet. To check the timer set the timer mid scale air only, this should disconnect the heating coil so it does not confuse your readings. Unplug the unit. Use the most sensitive scale on your meter. Disconnect the wire/wires from C on the timer and measure across C to B. Should be 0 ohms. But before doing the above I would check the power. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. Be careful as 240 volts is lethal !!!
__________________
Quote:
I set the timer to No heat fluff for 10 mins, unplugged the unit and disconnected the wire harness from ABCH leaving the other two harnesses connected. My meter showed no continuty between C and B. Regarless of which ohms setting I put the meter on, it read "1". I know the meter is working fine. Does this mean the timer is bad? |
| Display Modes | |
| Roper dryer | Sherry Penland | Dryer Repair | 1 | 02-01-2011 02:10 PM |
| roper gas dryer | shar16bear | Dryer Repair | 0 | 12-14-2009 10:40 AM |
| Help! Roper Dryer | rgvjason | Dryer Repair | 5 | 05-05-2009 09:37 PM |
| roper dryer | MariaHoewischer | Dryer Repair | 1 | 12-02-2008 02:45 AM |
| roper dryer no go | joeyrat | Dryer Repair | 0 | 01-12-2008 03:15 PM |
