Dryer heat turns on, then turns off and stays off, it might turn on after a while, clothes are not drying. Heat turns on for about 50 seconds at the beginning. I have changed the Igniter, Coils, and 1 thermostat, still having the same issue.
Any ideas?
I have also checked for clogged vents.
..... nothing helped so far.
