Discuss
Trys to spin, but won't
 in
Dryer Repair
HI THERE, I HAVE A SEARS ELECTRIC DRYER. ABOUT A YEAR AGO I REPLACED THE DRIVE MOTOR. NOW THE MOTOR
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Trys to spin, but won't
  #1 (permalink)
Old 05-14-2009, 10:26 AM
Junior Member
PMC88875 is on a distinguished road
Default Trys to spin, but won't
Brand: Sears   Age: 5 - 10 years
HI THERE, I HAVE A SEARS ELECTRIC DRYER. ABOUT A YEAR AGO I REPLACED THE DRIVE MOTOR. NOW THE MOTOR SEEMS TO TURN BUT WHEN YOU PUT MORE THAN A FEW ITEMS IN THE DRYER IT DOESN'T WANT TO SPIN THE DRUM. I HAVE TO TAKE MOST OF THE CLOTHES OUT, HOLD THE SAFETY SWITCH AND MANUALLY TURN THE DRUM BY HAND UNTIL IT STARTS TO GO ON ITS OWN. IS IT THE MOTOR AGAIN OR THE BELT (I ALSO REPLACED THE BELT WHEN I REPLACED THE MOTOR. YOUR THOUGHTS?
Ads By Google
  #2 (permalink)
Old 05-14-2009, 05:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to disassemble the dryer and inspect the belt and the motor. What is the complete model number of the dryer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-18-2009, 06:27 PM
Junior Member
Default
MODEL 3110.60832990. Disassembly and back together is the easy part. Done it several times. Since the motor is only about 1 year old, the only other moving parts are the belt, tension pully and the roller guide. Sometimes I find the drum out of align and have to take it apart and put it back together again. Could the belt be stretched? Thanks Phil
  #4 (permalink)
Old 05-18-2009, 07:56 PM
Junior Member
Default
Also, I can get it to start turning by putting less weight in the drum. I have to get it started by turning it by hand and then closing the door quickly. Phil
  #5 (permalink)
Old 05-18-2009, 09:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to inspect all moving parts. Also make sure the belt goes around the idler and the motor pulleys as shown on the diagram.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't spin on rinse cycle or high spin bry21317 Washer Repair 10 05-24-2011 12:25 PM
Maytag Neptune Super Stack will not spin while in spin cycle. Vohn Washer Repair 2 11-04-2010 08:30 AM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
Dryer trys to start but drum will not spin Barry Lawley Dryer Repair 1 08-01-2009 06:35 PM
Trys to Start John C. Dryer Repair 2 04-19-2008 09:46 AM
