I have replaced the thermal limiter, the thermodisc, and now the heater coil assembly, the dryer now gets hot but still turns off after 10 mins. HELP im running out of things to replace!!!
you most likely have stuff in the exhaust not letting it blow out the heat. most common problem with overheating.
