Discuss
remove top cover
 in
Dryer Repair
Hi, Before I make any assumptions about how I remove the top cover to check/replace the door switch; can someone
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » remove top cover
  #1 (permalink)
Old 05-13-2009, 11:25 AM
Junior Member
MikMac is on a distinguished road
Default remove top cover
Model Number: TEDS840JQ2   Brand: Estate   Age: 5 - 10 years
Before I make any assumptions about how I remove the top cover to check/replace the door switch; can someone tell me how to do it? Thanks.
Ads By Google
Related Models
Whirlpool TEDS840JQ2
Whirlpool TEDS840JQ3 29"electric Dryer
Whirlpool TEDS840PQ0 29"electric Dryer
Whirlpool TEDS840PQ1 29"electric Dryer
Whirlpool TEDX340RW0 29" Electric Dryer
Whirlpool TEDX340RW1 29" Electric Dryer
Whirlpool TEDX340RW2 29" Electric Dryer
Whirlpool TEDX540RQ0 29" Electric Dryer
Whirlpool TEDX540RQ1 29" Electric Dryer
Whirlpool TEDX640EQ0
Whirlpool TEDX640EQ1
Whirlpool TEDX640EQ2
Whirlpool TEDX640JQ0
Whirlpool TEDX640JQ1
Whirlpool TEDX640JQ2 29"electric Dryer
Whirlpool TEDX640PQ0 29" Electric Dryer
Whirlpool TEDX640PQ1 29"electric Dryer
Frigidaire TEF240PHD1 Tap(v1) / Electric Range
Frigidaire TEF240PHW1 Tap(v2) / Electric Range
Tappan TEF240PHW2 Tappan/electric Range
Tappan TEF242BU1 Tappan/electric Range
Tappan TEF242BU2 Tappan/electric Range
Tappan TEF242BU3 Tappan/electric Range
Tappan TEF242BW1 Tappan/electric Range
Tappan TEF242BW2 Tappan/electric Range
Tappan TEF242BW3 Tappan/electric Range
Tappan TEF303AWA Tappan/range
Tappan TEF303AWB Tappan/electric Range
Tappan TEF303BWA Tappan/electric Range
Tappan TEF303BWB Tappan/electric Range
Tappan TEF303BWC Tappan/electric Range
Tappan TEF303BWD Tappan/electric Range
Tappan TEF303BWE Tappan/range
Tappan TEF317AUA Tappan/range
Tappan TEF317AUB Tappan/electric Range
Tappan TEF317AWA Tappan/range
Tappan TEF317AWB Tappan/electric Range
Tappan TEF317AWC Tappan/electric Range
Tappan TEF317BUA Tappan/electric Range
Tappan TEF317BUB Tappan/electric Range
Tappan TEF317BUC Tappan/electric Range
Tappan TEF317BUD Tappan/electric Range
Tappan TEF317BWA Tappan/electric Range
Tappan TEF317BWB Tappan/electric Range
Tappan TEF317BWC Tappan/electric Range
Tappan TEF317BWD Tappan/electric Range
Tappan TEF317BWE Tappan/electric Range
Frigidaire TEF322BHDA
Frigidaire TEF322BHWA
Frigidaire TEF322SCDA Tap(v1) / Electric Range
Frigidaire TEF322SCDB Tap(v1) / Electric Range
Frigidaire TEF322SCDC Tap(v1) / Electric Range
Frigidaire TEF322SCWA Tap(v2) / Electric Range
Frigidaire TEF322SCWB Tap(v2) / Electric Range
Frigidaire TEF322SCWC Tap(v2) / Electric Range
Frigidaire TEF322WHSA
Frigidaire TEF324BCDA Tap(v1) / Electric Range
Frigidaire TEF324BCDB Tap(v3) / Electric Range
Frigidaire TEF324BCDC Tap(v3) / Electric Range
Frigidaire TEF324BCWA Tap(v2) / Electric Range
Frigidaire TEF324BCWB Tap(v4) / Electric Range
Frigidaire TEF324BCWC Tap(v4) / Electric Range
Frigidaire TEF324CCSA Tap(v0) / Electric Range
Frigidaire TEF324CCSB Tap(v5) / Electric Range
Tappan TEF326FBA Tappan/range
Tappan TEF326FSA Tappan/range
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
Frigidaire TEF352SCWB Tap(v2) / Electric Range
Frigidaire TEF352SCWC Tap(v2) / Electric Range
Frigidaire TEF352SCWD Tap(v2) / Electric Range
Tappan TEF353AQA Tappan/range
Tappan TEF353AQB Tappan/electric Range
Tappan TEF353AQC Tappan/electric Range
Tappan TEF353AQD Tappan/electric Range
Tappan TEF353AQE Tappan/range
Tappan TEF353AQF Tappan/electric Range
Tappan TEF353ASA Tappan/range
Tappan TEF353ASB Tappan/electric Range
Tappan TEF353ASC Tappan/electric Range
Tappan TEF353ASD Tappan/electric Range
Tappan TEF353ASE Tappan/range
Tappan TEF353ASF Tappan/electric Range
Tappan TEF353AUA Tappan/range
Tappan TEF353AUB Tappan/electric Range
Tappan TEF353AUC Tappan/electric Range
Tappan TEF353AUD Tappan/electric Range
Tappan TEF353AUE Tappan/range
Tappan TEF353AUF Tappan/electric Range
Tappan TEF353AWA Tappan/range
Tappan TEF353AWB Tappan/electric Range
Tappan TEF353AWC Tappan/electric Range
Tappan TEF353AWD Tappan/electric Range
  #2 (permalink)
Old 05-15-2009, 06:53 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi MikMac
On your machine there is the lint screen on the top. Remove this and you will see two screws in the lint screen receptacle area. Remove them and then "pop" up the top from the front. This will give you access to the door switch.
Good luck, and let us know if you have any difficulty or need further help.
__________________
  #3 (permalink)
Old 05-15-2009, 08:48 AM
Junior Member
Default
sidfink43, thanks.
After I posted my request, I found the scematic for the dryer on the AAP web-site and used that and another thread with a similiar door switch issue to solve my problem. Dryer works great. AAP probably saved me close to $100 in a service call on this one!
  #4 (permalink)
Old 05-15-2009, 10:43 AM
Senior Expert
APP Volunteer
Default
Great, glad it worked out and thanks for updating us
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to remove ice/water despenser cover? rjmadland Refrigerator & Freezer Repair 9 02-02-2011 02:18 PM
How Do You Remove Sump Cover? Raredude Dishwasher Repair 0 02-20-2010 03:40 PM
remove timer cover and damper cover fle Refrigerator & Freezer Repair 1 02-09-2010 05:23 PM
How can I remove the cover to get inside manx651 Dryer Repair 1 09-18-2009 04:19 AM
Remove cover from cooktop PartlyCloudy Oven Repair (including Ranges and Cooktops) 1 04-19-2009 08:58 AM
