Discuss
Access To The Heat Duct Assembly-coils
 in
Dryer Repair
Dear Sirs, Our dryer (Maytag-MDE5806AYW) started producing a smoky smell last night and I discovered that lint had gone through
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Access To The Heat Duct Assembly-coils
  #1 (permalink)
Old 05-13-2009, 07:38 AM
Junior Member
shirleyc is on a distinguished road
Default Access To The Heat Duct Assembly-coils
Model Number: MDE5806AYW   Brand: Maytag   Age: 1 - 5 years
Dear Sirs,
Our dryer (Maytag-MDE5806AYW) started producing a smoky smell last night and I discovered that lint had gone through the heating duct (and heating elements) and collected on the screen going into the dryer drum. I took off the front of the drying thinking I could get to the screen but no luck. Here are my questions:
- Do I take off the drum assy to get to the heating duct or take off the outside cabinet?
- Also, does the air get pulled into the heating elements/duct from the void below the drum? (There was a lot of lint in the bottom of the dryer and I wonder will this problem happen again and what is causing the lint build up?)
- Should I replace some of the common parts that wear out while I am in there for major surgery? (Limit thermostat, fuse, cylinder roller, etc)
- How do I get the drum belt back on/off? Replace thermo, fuse, roller, etc.?
The manuals are not available so I need some directions.
Thank you, C Shirley (shirleyc)
Ads By Google
Related Models
Maytag MDE5806AYW DRYER- ELE
Maytag MDE5806AZK DRYER- ELE
Maytag MDE5806AZW DRYER- ELE
Maytag MDE5960AYW DRYER- ELE
Maytag MDE6000AUW DRYER- ELE
Maytag MDE6000AYQ DRYER- ELE
Maytag MDE6000AYW DRYER- ELE
Maytag MDE6000AZQ DRYER- ELE
Maytag MDE6000AZW DRYER- ELE
Maytag MDE6200AYQ DRYER- ELE
Maytag MDE6200AYW DRYER- ELE
Maytag MDE6200AZQ DRYER- ELE
Maytag MDE6200AZW DRYER- ELE
Maytag MDE6400AGW DRYER- ELE
Maytag MDE6400AYQ DRYER- ELE
Maytag MDE6400AYW DRYER- ELE
Maytag MDE6400AZW DRYER- ELE
Maytag MDE6460AYW DRYER- ELE
Maytag MDE6460AZW DRYER- ELE
Maytag MDE6657BYQ DRYER- ELE
Maytag MDE6657BYW DRYER- ELE
Maytag MDE6700AYW DRYER- ELE
Maytag MDE6700AZW DRYER- ELE
Maytag MDE6800AYQ DRYER- ELE
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
Maytag MDE9606AYW DRYER- ELE
Maytag MDE9606AZA DRYER- ELE
Maytag MDE9606AZQ DRYER- ELE
Maytag MDE9606AZW DRYER- ELE
  #2 (permalink)
Old 05-13-2009, 08:25 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for MAYTAG MDE5806AYW | AppliancePartsPros.com
Here is a service manual and a wiring diagram
http://www.servicematters.com/maytag...s/16026315.pdf
http://www.servicematters.com/maytag...s/16027523.pdf
Do not quite understand the above. The lint screen just inside the door should pull up and out for regular cleaning before every load.
See the manual
Yes
Check that the blower is sealed to the exhaust duct, it may be blowing lint into the machine instead of out the duct.
I would not bother with thermostats as long as the dryer is heating OK and is regulating properly at the different temperature settings.
I would check the belt, the rear rollers, the idler roller, the drum seals, the front glides etc.
Check the rollers for wear including the shafts and bearing slop.
Give the inside a good cleaning including the motor and blower wheel.
Also clean and check your vent system.
See the manual
Hope this helps!!
__________________
  #3 (permalink)
Old 05-13-2009, 08:47 AM
Junior Member
Default Thank You
Denman,
Thank you! The manual will really help. Based on the answers to my questions I need to clean the "void" area really well make sure the duct is seated better and get to the heater duct and make sure that it is cleaned also before restarting. I will just take out the drum to get to all of this and then replace went done. I will check the other parts for wear.
Thank you for your help. C Shirley
  #4 (permalink)
Old 05-15-2009, 08:11 AM
Junior Member
Default Ok- Now It Runs But Will Not Heat
Dear Sirs,
See the string below. Got rid of burnt lint but now the dryer will not heat.
All of this was pretty easy and went very well. Other than burned lint on the coils everything looked great inside. While I was in there I vacumed around everything including the motor, etc. It was all clean. I did not disconnect any electrical connects except the light switch and dampness bar connections. However, now when I turn it on it works fine except no heat at any setting. I rechecked all connections and ran the diagnostics and receive the following service codes: 22, 21 and 14- Dryness sensor- Selected dryer temp not reached- Heater on and drum temp not increasing.)I then talked to the local Maytag guys about what they thought it might be. No real help other than suggesting that when cleaning the motor I might have hit the "Red centerfuge switch". (???) I havn't checked this yet but is this a viable option to the dryer not heating if it did so perfectly before I took it apart to clean? Any other suggestions? I have an ohm meter and can check the other parts if you can suggest what might fail by the me just pulling things apart and cleaning out the lint? I will try most anything that you suggest.
Thank you in advance.
C Shirley
  #5 (permalink)
Old 05-15-2009, 06:45 PM
Senior Expert
APP Volunteer
Default
First turn the breaker off/on slowly.
Give it a try
If no heat
Then check for 240 volts at the plug. Sometimes half the line can drop out with no visual indication from the breaker.
If OK
Unplug the unit
Open up the console and check that a plug has not come loose on the control board. Would not hurt to disconnect/reconnect them just top be sure.
Plug it in and give it a try
If no heat
Unplug the unit
Check both the thermostats, both should be 0 ohms
Check the heater, should be around 10 ohms.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Duct Inlet Assembly stanco39 Dryer Repair 4 12-04-2009 01:03 PM
Help with removing Air Duct from front door assembly wdc41073 Dryer Repair 0 10-22-2009 07:05 AM
Replacing front air duct assembly SRosie Dryer Repair 1 09-17-2009 05:20 PM
How to gain access to the Gas Valve Coils MonsterBash Dryer Repair 1 02-02-2009 05:05 PM
How to remove panels to access coils Davidrod777 Dryer Repair 3 08-22-2008 10:25 AM
