saja
#1 Posted : Tuesday, May 12, 2009 4:15:49 PM(UTC)
saja
The dryer heats just fine and drys the loads no problem. The timing dial does advance in all drying modes but continues to advance and never shuts off. The dryer will stop when the door is opened. Any thoughts?
#2 Posted : Wednesday, May 13, 2009 3:31:30 AM(UTC)
Replacement parts for WHIRLPOOL LER4434AW0 | AppliancePartsPros.com
Here is a wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203396197.pdf
Could be that timer contacts BU/BK are welded together so they never open.
To check you will need a meter.
Unplug the unit.
Turn the dial to Off
Remove the blue wire from the timer and measure across the contacts.
Should be an open (infinity ohms).
If welded together you will get 0 ohms
Sometimes you can clean the contacts and get a few more months out of the timer but it is best to just replace it.
saja
#3 Posted : Wednesday, May 13, 2009 5:15:22 AM(UTC)
saja
Thanks for the quick resonse. We'll give this a try and see how it goes.
Amana dryer will not shut off on automatic cycles (Dryer Repair)
by Nutforbriggs 4/21/2016 11:42:33 AM(UTC)
Maytag MDE7658BYW Timer not advancing/dryer will not shut off (Dryer Repair)
by countrybois 6/13/2014 10:47:30 AM(UTC)
Dryer will not shut off (Dryer Repair)
by patpeery@aol.com 11/22/2012 10:01:07 AM(UTC)
Whirlpool dryer will not shut off after new timer replacement (Dryer Repair)
by grayfeathers 10/23/2012 4:23:08 PM(UTC)
Dryer will not shut off in automatic cycle (Dryer Repair)
by jennarnott 6/21/2012 12:02:09 PM(UTC)
Dryer will not Shut off (Dryer Repair)
by Jeremybrutonsupply 5/25/2012 6:00:53 AM(UTC)
HELP! Dryer will not shut off & timer won't advance (Dryer Repair)
by csutliff 4/11/2012 10:17:10 AM(UTC)
Maytag Dryer Will Not Shut Off (Dryer Repair)
by MJScott 3/20/2012 11:35:17 AM(UTC)
Maytag Dryer Will Not Shut Off (Refrigerator & Freezer Repair)
by MJScott 3/20/2012 11:27:36 AM(UTC)
kenmore dryer will not shut off and will start when the timer is on zero (Dryer Repair)
by brettb 12/13/2011 4:05:19 PM(UTC)
LDG8414AAE Maytag Dryer will not shut off (Dryer Repair)
by skora 11/3/2011 11:42:33 AM(UTC)
by GWG 12/30/2010 7:53:55 AM(UTC)
Dryer will not shut off but heats ok (Dryer Repair)
by twilliams0204 12/16/2010 6:26:06 PM(UTC)
by fixit33 10/4/2010 4:08:20 AM(UTC)
Dryer will not shut off. (Dryer Repair)
by jmkitson 8/5/2010 11:23:31 AM(UTC)
