Discuss
looses heat
 in
Dryer Repair
gas drier fails to always fully dry load. i have checked the bimetal switch used to sense the electric ighition
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » looses heat
  #1 (permalink)
Old 05-12-2009, 01:07 PM
Junior Member
Dan Devir is on a distinguished road
Angry looses heat
Brand: Maytag   Age: More than 10 years
gas drier fails to always fully dry load. i have checked the bimetal switch used to sense the electric ighition heater it functions, the ignition heater functions, the ignition is on for about five seconds , I have observed it to fade to black just as the gas ignights, it appears to be a borderline heater timing issue, I did reset the heater a bit closet to the sensor, seemed to help,a bit....but not fully.......I will relocate it bit closer to the sensor.....In the mean time does any have info on How to increase the time the ignition heater is on
Ads By Google
  #2 (permalink)
Old 05-12-2009, 10:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The igniter should stay "on" only until the gas lights up. Do not do any alteration!
What is the complete model number of the dryer? What is the original problem?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Normal Heat Empty, Heat Shuts Off Full BigDaddyG Dryer Repair 4 08-06-2009 03:17 PM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 10:11 AM
