[COLOR="Red"]djagroop[/COLOR]
Please start your own thread using Post New Topic.
Hijacking another persons thread will just confuse things unless everything that applies to that person also applies to you.
sbsbadenHere are your parts
Replacement parts for MAYTAG LDE9900BCW DRYER- ELE | AppliancePartsPros.comCould be the power to the unit. The heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!![/COLOR]
Could be one of the thermostats/fuses in the heater circuit.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
