Discuss
dryer repair
 in
Dryer Repair
I have a whirlpool dryer model leb6200pqo and it stopped working. I checked and the thermal fuse is bad. It
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer repair
  #1 (permalink)
Old 05-11-2009, 05:42 PM
Junior Member
marc74or is on a distinguished road
Default dryer repair
Model Number: leb6200pq0   Brand: Whirlpool   Age: 1 - 5 years
I have a whirlpool dryer model leb6200pqo and it stopped working. I checked and the thermal fuse is bad. It says if that is bad I should replace the thermal fuse and the operating thermostat. Which one is the operating thermostat? If I by pass the thermal fuse the machine comes on but no heat. I checked the element and it is good. So does that mean I do need the operating thermostat too? Or do I need a thermal cutoff too?
Related Models
Whirlpool LEB6200PQ0 29" ELECTRIC DRYER
Whirlpool LEB6200PQ1 29"ELECTRIC DRYER
Whirlpool LEB6300LW0 RESIDENTIAL DRYER
Whirlpool LEB6300LW1 29"ELECTRIC DRYER
Whirlpool LEB6300PW0 29"ELECTRIC DRYER
Whirlpool LEB6300PW1 29"ELECTRIC DRYER
Whirlpool LEB6400KQ0 RESIDENTIAL DRYER
Whirlpool LEB6400KQ1 RESIDENTIAL DRYER
Whirlpool LEB6400LW0 RESIDENTIAL DRYER
Whirlpool LEB6400LW1 29"ELECTRIC DRYER
Amana LEC10AW DRYER- ELE
Admiral LEC1330AAB SURFACE UNIT- ELE
Admiral LEC1330AAC SURFACE UNIT- ELE
Admiral LEC1330AAW SURFACE UNIT- ELE
Amana LEC20AW DRYER- ELE
Amana LEC30AW DRYER- ELE
Amana LEC32AW DRYER- ELE
Whirlpool LEC5000PQ0 29" ELECTRIC DRYER
Whirlpool LEC5000PQ1 29" ELECTRIC DRYER
Amana LEC50AW DRYER- ELE
Amana LEC60AW DRYER- ELE
Whirlpool LEC6646AN0 ELECTRIC DRYER
Whirlpool LEC6646AN1 ELECTRIC DRYER
Whirlpool LEC6646AN2 ELECTRIC DRYER
Whirlpool LEC6646AQ0 Residential Dryer
Whirlpool LEC6646AQ1 ELECTRIC DRYER
Whirlpool LEC6646AQ2 ELECTRIC DRYER
Whirlpool LEC6646AW0 Residential Dryer
Whirlpool LEC6646AW1 ELECTRIC DRYER
Whirlpool LEC6646AW2 ELECTRIC DRYER
Whirlpool LEC6646AZ1 ELECTRIC DRYER
Whirlpool LEC6646AZ2 ELECTRIC DRYER
Whirlpool LEC6646AZO ELECTRIC DRYER
Whirlpool LEC6848AN0 ELECTRIC DRYER
Whirlpool LEC6848AN1 ELECTRIC DRYER
Whirlpool LEC6848AN2 ELECTRIC DRYER
Whirlpool LEC6848AN3 ELECTRIC DRYER
Whirlpool LEC6848AQ0 Residential Dryer
Whirlpool LEC6848AQ1 ELECTRIC DRYER
Whirlpool LEC6848AQ2 ELECTRIC DRYER
Whirlpool LEC6848AQ3 ELECTRIC DRYER
Whirlpool LEC6848AW0 ELECTRIC DRYER
Whirlpool LEC6848AW1 TECH SHEET - DRYER - REVISION REL.
Whirlpool LEC6848AW2 ELECTRIC DRYER
Whirlpool LEC6848AW3 ELECTRIC DRYER
Whirlpool LEC6848AZ1 ELECTRIC DRYER
Whirlpool LEC6848AZ2 ELECTRIC DRYER
Whirlpool LEC6848AZ3 ELECTRIC DRYER
Whirlpool LEC6858AQ3 ELECTRIC DRYER
Whirlpool LEC7646DQ0 ELECTRIC DRYER
Whirlpool LEC7646DQ1 ELECTRIC DRYER
Whirlpool LEC7646DZ0 ELECTRIC DRYER
Whirlpool LEC7646DZ1 ELECTRIC DRYER
Whirlpool LEC7848DQ0 ELECTRIC DRYER
Whirlpool LEC7848DQ1 ELECTRIC DRYER
Whirlpool LEC7848DZ0 ELECTRIC DRYER
Whirlpool LEC7848DZ1 ELECTRIC DRYER
Whirlpool LEC7858AN0 ELECTRIC DRYER
Whirlpool LEC7858AN1 ELECTRIC DRYER
Whirlpool LEC7858AN2 ELECTRIC DRYER
Whirlpool LEC7858AQ0 ELECTRIC DRYER
Whirlpool LEC7858AQ1 ELECTRIC DRYER
Whirlpool LEC7858AQ2 ELECTRIC DRYER
Whirlpool LEC7858AW0 Residential Dryer
Whirlpool LEC7858AW1 ELECTRIC DRYER
Whirlpool LEC7858AW2 ELECTRIC DRYER
Whirlpool LEC7858AZ0 ELECTRIC DRYER
Whirlpool LEC7858AZ1 ELECTRIC DRYER
Whirlpool LEC7858AZ2 ELECTRIC DRYER
Amana LEC80AW DRYER- ELE
Whirlpool LEC8858DQ0 ELECTRIC DRYER
Whirlpool LEC8858DQ1 ELECTRIC DRYER
Whirlpool LEC8858DZ0 ELECTRIC DRYER
Whirlpool LEC8858DZ1 ELECTRIC DRYER
Whirlpool LEC8858EQ0 ELECTRIC DRYER
Whirlpool LEC8858EQ1 DRYERS
Whirlpool LEC8858EQ2 ELECTRIC DRYER
Whirlpool LEC8858EZ0 ELECTRIC DRYER
Whirlpool LEC8858EZ1 DRYERS
Whirlpool LEC8858EZ2 ELECTRIC DRYER
Whirlpool LEC9000PW0 29" ELECTRIC DRYER
Whirlpool LEC9000PW1 29" ELECTRIC DRYER
Amana LEC90AW DRYER- ELE
Frigidaire LECR23EFE0 Frigidaire/refrigerator
Frigidaire LECR23EFE1 REFRIGERATOR
Frigidaire LECR23EFE2 REFRIGERATOR
Frigidaire LECR23EFE3 REFRIGERATOR
Amana LED20AW DRYER- ELE
Amana LED250 WASHER-TOP LOADING
Amana LED250 DRYER- ELE
Amana LED302 DRYER- ELE
Amana LED302 WASHER-TOP LOADING
Amana LED32AW DRYER- ELE
Amana LED450 WASHER-TOP LOADING
Amana LED450 DRYER- ELE
Amana LED502 DRYER- ELE
Amana LED57AW DRYER- ELE
Amana LED65AW DRYER- ELE
Amana LED850 WASHER-TOP LOADING
Amana LED850 DRYER- ELE
Amana LED902 DRYER- ELE
Amana LED950 WASHER-TOP LOADING
Amana LED950 DRYER- ELE
Frigidaire LEDB400FEE0 Frigidaire/dishwasher
Frigidaire LEDB500FEE0 Frigidaire Elements/dishwasher
Whirlpool LEE9848BQ0 ELECTRIC DRYER
Whirlpool LEE9848BQ1 ELECTRIC DRYER
Whirlpool LEE9848BQ2 ELECTRIC DRYER
Whirlpool LEE9848BZ0 ELECTRIC DRYER
Whirlpool LEE9848BZ1 ELECTRIC DRYER
Whirlpool LEE9848BZ2 ELECTRIC DRYER
Frigidaire LEEB30S9FEA Frigidaire/wall Oven
Frigidaire LEEB30T9FEA Frigidaire/wall Oven
Frigidaire LEEC30S9FEA Frigidaire/cooktop
Frigidaire LEEC36S9FEA Frigidaire/cooktop
Frigidaire LEEFM389FEA Frigidaire/electric Range
Frigidaire LEEFM389FEB Frigidaire/electric Range
  #2 (permalink)
Old 05-12-2009, 05:34 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
It would most likely be a the thermal fuse. Do you not have a ohm meter? The operating thermostat is the 4 wire thermostat. It will most likely not be the culprit. Tom ********************************************
  #3 (permalink)
Old 05-12-2009, 05:58 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL LEB6200PQ0 | AppliancePartsPros.com
Here is a wiring diagram
https://www.servicematters.com/docs/...%208528187.pdf
Check that you have 240 volts at the plug.
The heater and the timer require 240 to operate. It is not uncommon to loose half the line without actually tripping the breaker.
Turn the breaker off/on slowly a couple times.
I assume that you checked it with a meter.
Did you remove both wires from the heater and check between them for resistance, should be approximately 10 ohms. And also then check from each terminal to the case, to ensure you do not have a grounded element.
Check both of these with your meter.
Both should be 0 ohms at room temperature.
Note on your operating thermostat one set of connectors are the switch contacts (0 ohms), the other set is an internal heating element used to change the temp settings of the dryer (approximately 7,000 ohms)
Since the thermal fuse blew it is important to check/clean the blower wheel and your vent system.
__________________
  #4 (permalink)
Old 05-12-2009, 07:02 PM
Junior Member
Default
thanks for the info I found the problem it was the thermal fuse
  #5 (permalink)
Old 05-13-2009, 03:46 AM
Senior Expert
APP Volunteer
Default
Glad you got it fixed.
Have a good day
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer repair bfort41 Dryer Repair 1 12-28-2009 12:26 PM
dryer repair kens41 Dryer Repair 0 12-22-2009 04:58 AM
dryer repair avharris Dryer Repair 1 11-23-2009 06:55 AM
Dryer Repair Laurie Giersdorf Dryer Repair 1 09-24-2009 02:27 PM
Dryer Repair Horacio Dryer Repair 2 03-27-2008 05:43 PM
