lacer8
#1 Posted : Wednesday, October 26, 2011 10:01:30 PM(UTC)
lacer8
Hi there and thank you for your time.
I have an Amana LEA60AW. I recently purchased the:
#6 Dryer Thermal Fuse
#8 High Limit Thermostat
( Rear bulkhead, felt seal & rollers replacement parts for AMANA LEA60AW DRYER- ELE | AppliancePartsPros.com )
and
#24 Thermostat
( Motor and fan assemblies replacement parts for AMANA LEA60AW DRYER- ELE | AppliancePartsPros.com )
The thermostats I had no problem finding and replacing. I pulled off one wire at a time, connecting to the new part before switching the next wire over and bolted those up. But I couldn't find where the Thermal Fuse was supposed to go.
Then I realized that this being a used dryer, someone had likely done repairs to it and bypassed the fuse. The more I thought about it the more sure I am. Unfortunately, I'm unable to figure out how the wires should be connected, and don't want to guess on that. I've seen a wiring diagram but am not an electrical engineer.
I can see where the fuse should bolt on, but I'm hoping someone can look at this image and tell me how the wires should be connected.
Again, thanks for your time.
pUserPostedImage
lacer8 attached the following image(s):
lacer8
#2 Posted : Saturday, October 29, 2011 9:12:26 AM(UTC)
lacer8
Just thought I'd bump this and see if anyone can help.
thanks
p
#3 Posted : Sunday, October 30, 2011 3:32:19 AM(UTC)
Here is how it is currently hooked up
Black wire
Hi-limit connector A
Hi-limit thermostat
Hi-limit connector B
Black jumper wire
Heating coil connector A, also has the blue wire that goes to timer resistor.
Heating coil
Heating coil connector B
Orange wire
Here is how it should be hooked up
Black wire
Heating coil
Black jumper wire
Hi-limit thermostat
High limit connector B
Jumper wire. This is missing.
Thermal fuse connector A
Thermal fuse. This is missing
Thermal fuse connector B
Orange wire
You will have to make up or purchase a jumper wire to connect the hi-limit thermostat to the thermal fuse.
If you make one be sure to get high current connectors.
You could try calling AppliancePartsPros perhaps they will have one.
I think AP4290706 will do but am ot sure about this. It looks about 6 inches long but I am not sure about the connectors.
