Discuss
Kenmore dryer will not heat
 in
Dryer Repair
My electric Kenmore dryer runs fine, but it will not heat. Based on other posts in this forum I checked
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore dryer will not heat
  #1 (permalink)
Old 05-10-2009, 04:56 PM
Junior Member
lpennock is on a distinguished road
Default Kenmore dryer will not heat
Model Number: 66702690   Brand: Kenmore   Age: More than 10 years
Based on other posts in this forum I checked the airflow, which is good, and reset the circuit breaker several times. I also checked all the wiring for loose connections. Finally, I bypassed the 325F thermal fuse on the heater in case that had blown, but the heater element will still not heat.
What are my next steps? I guess I need to run and get a voltage meter to check continuity of the heating coil, but I am not entirely sure how to test it. If the problem is a bad heating coil, is this a part that I will be able to find?
-Lewis
Ads By Google
Related Models
Admiral 667AJ-TSAW Range - S/c F/s Ele
Admiral 667AK-TSAW Range - S/c F/s Ele
Admiral 667AK-TSVW Range - S/c F/s Ele
Admiral 667KK-TSAW Range - S/c F/s Ele
Admiral 667KK-TSVW Range - S/c F/s Ele
Admiral 667WJ-TSAW Range - S/c F/s Ele
Admiral 667WK-TSAW Range - S/c F/s Ele
Admiral 667WK-TSVW Range - S/c F/s Ele
Admiral 668AJ-ASAW Range - S/c F/s Ele
Admiral 668AK-TSAW Range - S/c F/s Ele
Admiral 668WJ-ASAW Range - S/c F/s Ele
Admiral 668WK-TSAW Range - S/c F/s Ele
Maytag 66CB Dryer - Gas
Hoover 67 Frigidaire/refrigerator
Hoover 671 Frigidaire Canada/electric Range
Admiral 671AH Range - F/s Std Gas
Admiral 671AH-K Range - F/s Std Gas
Admiral 671WH Range - F/s Std Gas
Admiral 671WH-K Range - F/s Std Gas
Admiral 673AJ-KV Range - F/s Std Gas
Admiral 673WJ-KV Range - F/s Std Gas
Admiral 674AJ-EKLVW Range - F/s Cont Clean Gas
Admiral 674AJ-EKVW Range - F/s Std Gas
Admiral 674AJ-EKW Range - F/s Std Gas
Admiral 674WJ-EKLVW Range - F/s Cont Clean Gas
Admiral 674WJ-EKVW Range - F/s Std Gas
Admiral 674WJ-EKW Range - F/s Std Gas
Admiral 675AJ-KVW Range - F/s Std Gas
Admiral 675AK-KLVW Range - F/s Cont Clean Gas
Admiral 675AK-KVW Range - F/s Std Gas
Admiral 675AM-KSVW Range - F/s Std Gas
Admiral 675LM-KSVW
Admiral 675WJ-KVW Range - F/s Std Gas
Admiral 675WK-KLVW Range - F/s Cont Clean Gas
Admiral 675WK-KVW Range - F/s Std Gas
Admiral 675WM-KSVW Range - F/s Std Gas
Admiral 676AJ-KSVW Range - F/s Std Gas
Admiral 676AK-KLSVW Range - F/s Cont Clean Gas
Admiral 676AK-KSVW Range - F/s Std Gas
Admiral 676AM-KLSVW Range - F/s Cont Clean Gas
Admiral 676AM-KSVW Range - F/s Std Gas
Admiral 676WJ-KSVW Range - F/s Std Gas
Admiral 676WK-KLSVW Range - F/s Cont Clean Gas
Admiral 676WK-KSVW Range - F/s Std Gas
Admiral 676WM-KLSVW Range - F/s Cont Clean Gas
Admiral 676WM-KSVW Range - F/s Std Gas
Maytag 67C Dryer - Gas
Hoover 68 White Westinghouse/range
Hoover 681
Admiral 684AJ-CKV Range - S/c F/s Gas
Admiral 684WJ-CKV Range - S/c F/s Gas
Admiral 685AJ-CKV Range - S/c F/s Gas
Admiral 685AJ-CKVW Range - S/c F/s Gas
Admiral 685WJ-CKV Range - S/c F/s Gas
Admiral 685WJ-CKVW Range - S/c F/s Gas
Admiral 686AJ-EKSVW Range - S/c F/s Gas
Admiral 686AJ-TKSVW Range - S/c F/s Gas
Admiral 686AK-EKSVW Range - S/c F/s Gas
Admiral 686AM-CKSV Range - S/c F/s Gas
Admiral 686AM-TKS Range - S/c F/s Gas
Admiral 686WJ-EKSVW Range - S/c F/s Gas
Admiral 686WJ-TKSVW Range - S/c F/s Gas
Admiral 686WK-EKSVW Range - S/c F/s Gas
Admiral 686WM-CKSV Range - S/c F/s Gas
Admiral 686WM-TKS Range - S/c F/s Gas
Admiral 687AF-CKVW Range - S/c F/s Gas
Admiral 687AJ-EKZW Range - S/c F/s Gas
Admiral 687AJ-TKSAW Range - S/c F/s Gas
Admiral 687AK-TKSAW Range - S/c F/s Gas
Admiral 687AM-TKSAW Range - S/c F/s Gas
Admiral 687WF-CKVW Range - S/c F/s Gas
Admiral 687WJ-EKZW Range - S/c F/s Gas
Admiral 687WJ-TKSAW Range - S/c F/s Gas
Admiral 687WK-TKSAW Range - S/c F/s Gas
Admiral 687WM-TKSAW Range - S/c F/s Gas
Magic Chef 6892VRA Range - S/c S/i Ele
Magic Chef 6892VRV Range - S/c S/i Ele
Magic Chef 6892VVA Range - S/c S/i Ele
Magic Chef 6892VVV Range - S/c S/i Ele
Magic Chef 6892XRA Range - S/c S/i Ele
Magic Chef 6892XRS Range - S/c S/i Ele
Magic Chef 6892XRW Range - S/c S/i Ele
Magic Chef 6892XVA Range - S/c S/i Ele
Magic Chef 6892XVB Range - S/c S/i Ele
Magic Chef 6892XVS Range - S/c S/i Ele
Magic Chef 6892XVW Range - S/c S/i Ele
Magic Chef 6893VVD Range - S/c S/i Ele
Magic Chef 6893VVV Range - S/c S/i Ele
Magic Chef 6893XVB Range - S/c S/i Ele
Magic Chef 6895VRA Range - S/c S/i Ele
Magic Chef 6895VRV Range - S/c S/i Ele
Magic Chef 6896VVD Range - S/c S/i Ele
Magic Chef 6896VVV Range - S/c S/i Ele
Magic Chef 6896XVB Range - S/c S/i Ele
Magic Chef 6898VRA Range - S/c S/i Ele
Magic Chef 6898VRV Range - S/c S/i Ele
Magic Chef 6898VVA Range - S/c S/i Ele
Magic Chef 6898VVD Range - S/c S/i Ele
Magic Chef 6898VVV Range - S/c S/i Ele
Magic Chef 6898XRA Range - S/c S/i Ele
Magic Chef 6898XRB Range - S/c S/i Ele
Magic Chef 6898XVB Range - S/c S/i Ele
Magic Chef 68HA-3CW Range - S/c S/i Ele
Magic Chef 68HA-3CXW Range - S/c S/i Ele
Magic Chef 68HA-4TVW Range - S/c S/i Ele
Magic Chef 68HA-4TXW Range - S/c S/i Ele
Magic Chef 68HA-6TVW Range - S/c S/i Ele
Magic Chef 68HK-6TXW Range - S/c S/i Ele
Magic Chef 68HN-3CXW Range - S/c S/i Ele
Magic Chef 68HN-4TVW Range - S/c S/i Ele
Magic Chef 68HN-4TXW Range - S/c S/i Ele
Magic Chef 68HN-6TVW Range - S/c S/i Ele
Magic Chef 68HN-6TVW-SC Range - S/c S/i Ele
Hoover 69
Hoover 691
Whirlpool 6ALBR6245JQ2 Automatic Washer
Whirlpool 6ALBR6245MW0 Automatic Washer
Whirlpool 6ALBR6245MW3 Automatic Washer
Whirlpool 6ALSC8255JQ2 Automatic Washer
Whirlpool 6ALSC8255MW0 Automatic Washer
  #2 (permalink)
Old 05-10-2009, 07:02 PM
Junior Member
Default
Update: I checked the continuity of the thermal fuse with a multi-tester to be sure, and it's fine. The heating element failed the continuity test, so that appears to be the problem. I can't seem to find a replacement heating element for this dryer anywhere, however. Any ideas?
-Lewis
  #3 (permalink)
Old 05-11-2009, 06:19 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Here is your heating element
WHIRLPOOL Whirlpool dryer heating element, part number: 279838
Your model number should have a 110 in front of it (indicates Whirlpool made the Dryer, check and make sure thisis the case). Use the model number you gave plus the 110 and you can find all your parts.
Good luck and let us know how it works out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dryer Will Not Heat Up mastaone Dryer Repair 1 11-09-2009 03:45 AM
Kenmore dryer will not heat vikingboy Dryer Repair 3 09-27-2009 02:00 PM
No Heat From Kenmore Gas Dryer grazzin Dryer Repair 2 09-16-2009 03:40 PM
Kenmore Dryer will not heat T.A.M. Dryer Repair 1 02-10-2009 06:28 PM
Kenmore Dryer No Heat mishdeme Dryer Repair 3 01-23-2008 06:56 PM
