Discuss
dryer has no heat/timer dying
 in
Dryer Repair
Need help, my dryer has stopped heating. At the same time the heat went completely out my timer went from
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer has no heat/timer dying
  #1 (permalink)
Old 05-08-2009, 06:57 PM
Junior Member
tomlizc is on a distinguished road
Angry dryer has no heat/timer dying
Model Number: TEDS740PQ1   Brand: Estate   Age: 1 - 5 years
Need help, my dryer has stopped heating. At the same time the heat went completely out my timer went from max of 60 min to over 2 hours without going off.
What parts will I need to fix this problem.
Thanks!
Ads By Google
Related Models
Whirlpool TEDS740PQ1 29"electric Dryer
Whirlpool TEDS780JQ0
Whirlpool TEDS840JQ0
Whirlpool TEDS840JQ1
Whirlpool TEDS840JQ2
Whirlpool TEDS840JQ3 29"electric Dryer
Whirlpool TEDS840PQ0 29"electric Dryer
Whirlpool TEDS840PQ1 29"electric Dryer
Whirlpool TEDX340RW0 29" Electric Dryer
Whirlpool TEDX340RW1 29" Electric Dryer
Whirlpool TEDX340RW2 29" Electric Dryer
Whirlpool TEDX540RQ0 29" Electric Dryer
Whirlpool TEDX540RQ1 29" Electric Dryer
Whirlpool TEDX640EQ0
Whirlpool TEDX640EQ1
Whirlpool TEDX640EQ2
Whirlpool TEDX640JQ0
Whirlpool TEDX640JQ1
Whirlpool TEDX640JQ2 29"electric Dryer
Whirlpool TEDX640PQ0 29" Electric Dryer
Whirlpool TEDX640PQ1 29"electric Dryer
Frigidaire TEF240PHD1 Tap(v1) / Electric Range
Frigidaire TEF240PHW1 Tap(v2) / Electric Range
Tappan TEF240PHW2 Tappan/electric Range
Tappan TEF242BU1 Tappan/electric Range
Tappan TEF242BU2 Tappan/electric Range
Tappan TEF242BU3 Tappan/electric Range
Tappan TEF242BW1 Tappan/electric Range
Tappan TEF242BW2 Tappan/electric Range
Tappan TEF242BW3 Tappan/electric Range
Tappan TEF303AWA Tappan/range
Tappan TEF303AWB Tappan/electric Range
Tappan TEF303BWA Tappan/electric Range
Tappan TEF303BWB Tappan/electric Range
Tappan TEF303BWC Tappan/electric Range
Tappan TEF303BWD Tappan/electric Range
Tappan TEF303BWE Tappan/range
Tappan TEF317AUA Tappan/range
Tappan TEF317AUB Tappan/electric Range
Tappan TEF317AWA Tappan/range
Tappan TEF317AWB Tappan/electric Range
Tappan TEF317AWC Tappan/electric Range
Tappan TEF317BUA Tappan/electric Range
Tappan TEF317BUB Tappan/electric Range
Tappan TEF317BUC Tappan/electric Range
Tappan TEF317BUD Tappan/electric Range
Tappan TEF317BWA Tappan/electric Range
Tappan TEF317BWB Tappan/electric Range
Tappan TEF317BWC Tappan/electric Range
Tappan TEF317BWD Tappan/electric Range
Tappan TEF317BWE Tappan/electric Range
Frigidaire TEF322BHDA
Frigidaire TEF322BHWA
Frigidaire TEF322SCDA Tap(v1) / Electric Range
Frigidaire TEF322SCDB Tap(v1) / Electric Range
Frigidaire TEF322SCDC Tap(v1) / Electric Range
Frigidaire TEF322SCWA Tap(v2) / Electric Range
Frigidaire TEF322SCWB Tap(v2) / Electric Range
Frigidaire TEF322SCWC Tap(v2) / Electric Range
Frigidaire TEF322WHSA
Frigidaire TEF324BCDA Tap(v1) / Electric Range
Frigidaire TEF324BCDB Tap(v3) / Electric Range
Frigidaire TEF324BCDC Tap(v3) / Electric Range
Frigidaire TEF324BCWA Tap(v2) / Electric Range
Frigidaire TEF324BCWB Tap(v4) / Electric Range
Frigidaire TEF324BCWC Tap(v4) / Electric Range
Frigidaire TEF324CCSA Tap(v0) / Electric Range
Frigidaire TEF324CCSB Tap(v5) / Electric Range
Tappan TEF326FBA Tappan/range
Tappan TEF326FSA Tappan/range
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
Frigidaire TEF352SCWB Tap(v2) / Electric Range
Frigidaire TEF352SCWC Tap(v2) / Electric Range
Frigidaire TEF352SCWD Tap(v2) / Electric Range
Tappan TEF353AQA Tappan/range
Tappan TEF353AQB Tappan/electric Range
Tappan TEF353AQC Tappan/electric Range
Tappan TEF353AQD Tappan/electric Range
Tappan TEF353AQE Tappan/range
Tappan TEF353AQF Tappan/electric Range
Tappan TEF353ASA Tappan/range
Tappan TEF353ASB Tappan/electric Range
Tappan TEF353ASC Tappan/electric Range
Tappan TEF353ASD Tappan/electric Range
Tappan TEF353ASE Tappan/range
Tappan TEF353ASF Tappan/electric Range
Tappan TEF353AUA Tappan/range
Tappan TEF353AUB Tappan/electric Range
Tappan TEF353AUC Tappan/electric Range
Tappan TEF353AUD Tappan/electric Range
Tappan TEF353AUE Tappan/range
Tappan TEF353AUF Tappan/electric Range
  #2 (permalink)
Old 05-09-2009, 04:01 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL TEDS740PQ1 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/docs/...%208576793.pdf
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Better yet measure the voltage at the plug.
L1 to L2 = 240 volts
L1 to Neutral and L2 to Neutral = 120 volts
Try the unit in timed dry.
Now does the timer advance?
If yes then odds are high that your heating element has burned out.
In Timed Dry this unit's timer motor gets it's power basically directly from the power in.
In Auto cycles it gets power through the heating element when the thermostat shuts the element off so if the heater goes, no power to the timer motor and no heat is the result.
Best to check it with a meter for resistance with the unit unplugged.
But usually you can see the broken filament.
Remember to unplug the machine when working on it.
240 VOLTS IS LETHAL
__________________
  #3 (permalink)
Old 05-09-2009, 02:26 PM
Junior Member
Default
Thank you for your reply!
I usually use the 60 minute timed cycle. It moved very slowly to the off position but took over two hours.
Just to clarify what parts I should order: heating element definitely
Should I order any of the following: thermal fuse, dryer cycling thermostat, thermal cut off for dyer heating element for 309 degress, thermaostat fixed
Thanks again for your help
Last edited by tomlizc : 05-09-2009 at 02:28 PM. Reason: hit wrong button needed to write more
  #4 (permalink)
Old 05-10-2009, 03:59 AM
Senior Expert
APP Volunteer
Default
I am assuming that the unit did shut itself off after the 2 hours and that the 240 volts is OK.
If this is correct then the most likely culprit is the timer.
Only if it is blown. Confirm this either visually or with a meter.
Note: it will have no effect on your timer problem as you are getting long run times in Timed Dry and it is not in circuit in Timed Dry mode
I would not unless you can confirm they are shot with a meter.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer timer AND heat ogmike1973 Dryer Repair 1 10-18-2009 04:07 AM
Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry dspeidel Dryer Repair 6 08-25-2009 02:23 PM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
dryer will not heat and the timer will not move nicole goldberg Dryer Repair 3 11-12-2008 05:28 PM
Gas dryer won't heat and timer not working mark55 Dryer Repair 3 12-30-2007 06:46 PM
