I need to remove the motor as the starter winding is gone, I have it appart but cannot figure out how to get the motor off the blower, Can someone help?
I cannot find any info on the given model number. Many blower wheels are screwed onto the motor shaft. They use reverse thread and can be a real pain to remove. You may have to destroy the blower wheel. Below is some info on this type. On other types you should be able to see a clip or clamp holding the wheel on. http://www.applianceaid.com/wpmotor-change.html |
THIS FORUM IS DEAD!!!!!!! |
