Discuss
whirlpool imperial dryer got wet won't run
 in
Dryer Repair
My son was drying a shirt in dryer while my other son overflowed the bathroom sink causing water to fall
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool imperial dryer got wet won't run
  #1 (permalink)
Old 12-09-2007, 10:53 AM
bobh4444 bobh4444 is offline
Junior Member
bobh4444 is on a distinguished road
Default whirlpool imperial dryer got wet won't run
Model Number: LET8858AW   Brand: -brand-   Age: 5 - 10 years
My son was drying a shirt in dryer while my other son overflowed the bathroom sink causing water to fall onto dryer. The dryer stopped working and now won't run. The circuit breaker is on and light inside and doorswitch seem to work. Any ideas?????
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-12-2007, 04:40 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Check water marks in the dryer, see if the motor is wet. If so, dry the motor in you oven. After that manually activate the start switch on the motor, then plug in 115 volts in pins 4 &5 and see if motor now runs, if not you have a bad motor start switch.
If timer got wet, put that in the oven to dry.
Please post results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Gas Dryer Mike B. Dryer Repair 0 12-09-2007 09:59 AM
whirlpool dryer mike@buster4 Dryer Repair 0 12-02-2007 12:05 PM
Whirlpool Dryer babe milam Dryer Repair 1 11-14-2007 12:46 PM
Whirlpool Imperial series Washer pratapgandhi Washer Repair 1 11-11-2007 01:02 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
