The problem is a plastic actuator has broken on the Start/Pause button. Understand I will need a new board for this fix, as I the plastic case is not sold separately Question: Is it just an unplug leads/re-plug or are there tests that a tech needs to perform after installation. There is not a problem with the internal switch.
